750 twin fitment
- Steely
750 twin fitment
25 Jan 2019 15:13
I know the twins don't fit into the 4 cylinder frames but why? Would it fit into a 650 csr frame? Obviously new mounts made but is it a size issue?
Re: 750 twin fitment
25 Jan 2019 15:21 - 26 Jan 2019 06:59
I wouldn't think so. The 750 Twin engine is narrower & taller. The 650-CSR has the same basic crankcase as a 750-4 & the frame is the same as a 750H Ltd. Just an FYI, there was a 750M CSR that's a twin, so that frame would work. I'd guess you've probably found a 650-CSR frame, but what the heck.
Last edit: 26 Jan 2019 06:59 by martin_csr.
- Steely
25 Jan 2019 16:44
I've built a csr frame but have a 78 to work with. Want to put a twin in it
- rstnick
25 Jan 2019 16:52
If you have the engine and frame, test fit it.
I would imagine the spacing between the exhaust headers and the two front frame down tubes may not work so well together, but I could be wrong.
Then there is the drive chain, the front sprocket needs to line up with the back sprocket.
I have seen many builds with an engine swapped into a different frame, even a kawi triple engine into a modern 250 Ninja frame.
Where there is a will, there is a way.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- Steely
25 Jan 2019 17:07
Don't have an engine building a frame looking for the right donor motor
- Steely
25 Jan 2019 19:33
I'm toying with the idea of an Xs650 motor for some crazy suspension design
26 Jan 2019 07:13 - 26 Jan 2019 07:27
So, you already had a 650-CSR frame & started modifying it before figuring out the engine fitment?
From memory from a comment by steell in an old topic, I'm pretty sure the 750 Twin engine is too tall for a 650 frame.
Last edit: 26 Jan 2019 07:27 by martin_csr.
