1982 Gpz 750 Front Forks Issue
- katastrophic
22 Jan 2019 08:52
Hi,
I'm currently rebuilding the gpz and I came across some noticeable stress marks /cracks on the inner fork tube of the left front shock (the bike took a fall with the previous owner).
Partzilla has it as PIPE-FORK INNER 44013-1089 which is no longer available, Ebay was of no luck either.
Are there any other kawas which uses the same fork tube or are there any other complete forks which can work in place of the original (without altering the triple, front axle, wheel and brakes)???
Thanks!!
Thanks!!
Re: 1982 Gpz 750 Front Forks Issue
22 Jan 2019 11:40 - 22 Jan 2019 11:40
KZ700A forks are similar. The difference from yours seems to be related to the air pressure system, which I recommend ditching (after getting some new Sonic springs).
There are a couple sets on ebay. Forking by Frank may be able to help too.
Last edit: 22 Jan 2019 11:40 by Nessism.
The following user(s) said Thank You: katastrophic
