Forks KZ750H
  • kawiwowi
  • kawiwowi's Avatar Topic Author
Forks KZ750H
05 Jan 2019 16:07
#796212
Going to replace the fork oil and seals. I have a KZ750 B1 but the forks are from a KZ750 H (not sure of the year-'80 or '81). What is the best oil to use for these? And how much? Thanks in advance for any suggestions.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Forks KZ750H
05 Jan 2019 16:34 - 05 Jan 2019 16:39
#796216
This should answer your question
Last edit: 05 Jan 2019 16:39 by Scirocco.
The following user(s) said Thank You: kawiwowi
  • kawiwowi
Re: Forks KZ750H
05 Jan 2019 17:08
#796218
Thanks for this!
  • gixxerkidd03
  • gixxerkidd03's Avatar
Re: Forks KZ750H
06 Jan 2019 21:03
#796325
Here is mine with 05 gsxr1000 front with cognito front hub and KZ hoop. I haven’t had an issue with ground clearance. Zrx1100 swingarm and a 180 rear tire
1981 KZ750e
  • martin_csr
  • martin_csr's Avatar
Re: Forks KZ750H
07 Jan 2019 06:28 - 07 Jan 2019 06:30
#796334
The manual says to use 10W fork oil, but some guys go with 15W. I use Bel-Ray fork oil. The 750-4 pdf manual has the fork free spring length spec. To pull the seals I use an off-the-shelf seal puller from the auto parts store & use milk jug plastic to protect the fork tube lowers. A small scrap of wood could be used, but the plastic works better. Be sure to use a hardened allen socket or brake caliper socket to remove the bottom allen bolts. a cheap tool could twist & damage the bolts.
1981 KZ650-CSR forks. the 750H forks should be the same.
Last edit: 07 Jan 2019 06:30 by martin_csr.
  • gordone
  • gordone's Avatar
Re: Forks KZ750H
07 Jan 2019 09:42 - 07 Jan 2019 09:43
#796348
martin_csr wrote: The manual says to use 10W fork oil, but some guys go with 15W. I use Bel-Ray fork oil. The 750-4 pdf manual has the fork free spring length spec. To pull the seals I use an off-the-shelf seal puller from the auto parts store & use milk jug plastic to protect the fork tube lowers. A small scrap of wood could be used, but the plastic works better. Be sure to use a hardened allen socket or brake caliper socket to remove the bottom allen bolts. a cheap tool could twist & damage the bolts.
Where can I get the inertool from?
Project:
Last edit: 07 Jan 2019 09:43 by gordone.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Forks KZ750H
07 Jan 2019 11:51
#796354
gordone it´s the screw with the two nuts threaded in the socket
  • martin_csr
Re: Forks KZ750H
07 Jan 2019 13:17 - 08 Jan 2019 07:30
#796359
Where can I get the innertool from?
Note: that homemade fork tool does not fit all forks. Assuming your forks are the same:
It is very simple >> Left-hand reverse threaded bolt w nuts. plus masking tape so it fits tight inside of a socket wrench.
The head of the inner cylinder is the same as a 19mm 12-pt socket wrench. use whatever fits that size socket. so get a bolt with 19mm head.
Someone else used a long bolt w a nut welded to the end of the bolt (see new pic. welded nut not shown).
In the USA. I used a 1/2 inch SAE bolt. a 3/4 inch wrench fits the bolt head. 3/4 inch = 19mm (approximate).
Note: bolts are sized by the diameter of the shaft, not the head of the bolt.
Last edit: 08 Jan 2019 07:30 by martin_csr.
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: Forks KZ750H
09 Jan 2019 16:50
#796457
I used a broom handle and that worked for me.
I've had success using just an impact wrench too.
1981 KZ750 LTD
  • gordone
  • gordone's Avatar
Re: Forks KZ750H
13 Jan 2019 06:39
#796669
What is these part, make the spring more stiffer ?
I don`t have it...
Project:
  • martin_csr
Re: Forks KZ750H
13 Jan 2019 07:43
#796676
Fork spring spacer. It adds tension to the fork springs. When installing the fork caps, you should feel the spring tension.
You'll have to decide if the spacers are needed. Someone may have installed longer springs or something. ???
  • Irish Yobbo
Re: Forks KZ750H
13 Jan 2019 13:14 - 13 Jan 2019 13:17
#796702
martin_csr wrote: Fork spring spacer. It adds tension to the fork springs. When installing the fork caps, you should feel the spring tension.
You'll have to decide if the spacers are needed. Someone may have installed longer springs or something. ???...
[strike]The spacers are definitely required, they were there from the factory on the 750 LTD models. They shared the spring with other models with shorter forks, and therefore needed the spacer for the longer forks of this model.[/strike]
Just re-read gordone's question and martin_csr's answer again. martin_csr is right, you'll just need to see how much tension is on the spring. If it's the original spring you'll need to make something up to replace it.
1981 KZ750 LTD
Last edit: 13 Jan 2019 13:17 by Irish Yobbo.
