Need help figuring out what model i have!
- agrestixrock
01 Jan 2019 07:07 - 01 Jan 2019 07:16
I recently bought a project kz650 for $250 with title. I noticed that on the title the engine size and model are unkown (UNK). Ive looked at websites which make it sound like its a B2 i will look for the specific parts it says can indicate it is a B2. The bike was 100% disassembled and the previous owner had the engine parts media blasted. I dont see any gaskets for it (which makes sense) but trying to make sure i buy the right kit. I have probably 6-7 boxes of parts which luckily every part was labeled and all bolts were placed in cardboard exactly how they were taken off. It does have a 4to1 exhaust with a kerker muffler so i wouldnt be surprised if other parts were changed i can take pictures of the engine # and stuff because i know thats the only way to tell.
Last edit: 01 Jan 2019 07:16 by agrestixrock. Reason: Typo
Re: Need help figuring out what model i have!
01 Jan 2019 07:39
Sometimes numbers printed in titles are not 100% accurate. The safest bet is to look at the VIN stamped in the steering stem neck of the bike's frame. It can be used to identify the year / model of the bike. Also, take a look at the serial number of the engine. It will be stamped next to the oil filler hole, and it can be used to identify the year of the engine. If you post both of those numbers here either I or someone else may be able to identify the year of the frame and engine. Ed
01 Jan 2019 08:14
There probably should be a zero after the KZ650B in the vin, so one or more of the numbers after the B are probably wrong.
CycleChaos.com has vin & engine number info for many Kawasaki motorcycles. The KZ650.Info site probably has the same info for all of the 650s.
- gd4now
- Denco where did you go?
01 Jan 2019 09:16
Agree if the number stamped on the neck is the same the frame began its life as a B2 built in the US.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- rstnick
01 Jan 2019 17:22martin_csr wrote: There probably should be a zero after the KZ650B in the vin, so one or more of the numbers after the B are probably wrong.
No, that's a correct VIN# for a Lincoln Nebraska built/assembled KZ650.
All Lincoln built KZs started with a #5.
models.kz650.info/Models.php
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- agrestixrock
14 Mar 2019 09:12
so i looked at the # on the frame and it appears to match the title. looks like a 77 . the pic is hard to read but it looks like it is the original engine. sorry it took so long to reply ive been really busy at work.
