Vetter saddle bags & 4 into 1 pipe?
  • 2strokerider
  • 2strokerider's Avatar Topic Author
09 Dec 2018 13:54
#794862
I tried to search on this but, does anyone have any idea if a set of vetter bags will work on a 1979 KZ1000ST that is running a 4 into 1 pipe? There is a set of vetter bags that came off an 80' KZ1000 Shafty for sale with the Vetter mounts. Any help is appreciated. TIA
  • TexasKZ
  • TexasKZ's Avatar
Re: Vetter saddle bags & 4 into 1 pipe?
09 Dec 2018 19:53
#794875
That depends on which pipe you are using. Some keep the muffler quite low and should present no problems with interferance. Some have a more modern look that puts the muffler at quite an angle and will likely make mounting the bags more of a challenge. Some are in between. You really need some measurements on the particular exhaust system you are using and from a bike with those bags mounted to know what will fit.
The following user(s) said Thank You: 2strokerider
  • 2strokerider
10 Dec 2018 07:37
#794881
Thanks and sorry for not being specific. I'm running a Delkovic pipe with the megaphone muffler. It looks to be a bit higher than the Kerker/Supertrapp.
Anyone running this combo?
TIA
