KZ200 Cables
- MurphyChow
KZ200 Cables
06 Dec 2018 05:53
Anyone got any spare cables for sale for a KZ200, mine came without handlebars and all the cables were cut. I need a Clutch, front brake, speedo, tach and throttle cable. I think I can make something work for the throttle & tach but everything else I might not be able to get away with. I am located in Raincouver BC, Canada. Im thinking about changing the brakes out from a KZ 650 . Anyways let me know Thanks in advance to anyone who can help!
Re: KZ200 Cables
06 Dec 2018 06:22 - 06 Dec 2018 06:22
Z1Enterprises.com has a tachometer cable for the KZ200, but I did not see any other cables listed.
I would get the part numbers at Partzilla, then search eebbaayy for nos oem cables.
If nothing is available, you'll have to figure out the lengths, then search other models at Z1Enterprises to see if cables from a different bike will work. Z1Ent has the lengths & slack or amount of end-to-end movement.
Last edit: 06 Dec 2018 06:22 by martin_csr.
Re: KZ200 Cables
06 Dec 2018 13:25
CMSNL listed Clutch, speedo, and throttle cable as available.
www.cmsnl.com/kawasaki-kz200a1-1978-cana...88.html#.XAmQRLmWw_w
I can upload a Service Manual if needed.
Re: KZ200 Cables
06 Dec 2018 13:33
No eBay APP ID and/or Cert ID defined in Kunena configurationAnd for the Tachometer
Tachometer Cable Made to fit:
•1979 Kawasaki KL250
•1978 Kawasaki KL250
•1979 Kawasaki KZ200
•1978 Kawasaki KZ200
•1983 Kawasaki KZ250
•1982 Kawasaki KZ250
•1981 Kawasaki KZ250
•1980 Kawasaki KZ250
•1977 Kawasaki KZ400/D
•1976 Kawasaki KZ400/D
•1975 Kawasaki KZ400/D
•1974 Kawasaki KZ400/D
Re: KZ200 Cables
06 Dec 2018 14:05
Re: KZ200 Cables
07 Dec 2018 05:49 - 07 Dec 2018 06:20
No eBay APP ID and/or Cert ID defined in Kunena configurationNice finds Scirocco. I only saw a tach cable at Z1Ent & eebbaayy. cmsnl.com has a pic of the brake cable but it's not available.
I wonder if Motion Pro could fab a new brake cable using that old one as a template?
Edit: this wasn't listed yesterday. waaay over-priced. I would make a low-ball offer, within reason using an est Kaw retail price as a guide.
Since this just popped up on eebbaayy, I'm wondering if it was listed as a result of my recent search of the part number. ???
Last edit: 07 Dec 2018 06:20 by martin_csr.
