brake caliper rebuilds
Re: brake caliper rebuilds
04 Dec 2018 11:47
The copper washers are soft and the arc will crush flatten when you install the brake line.
Don“t over tighten the Banjo bolts, they can snap easily.
05 Dec 2018 17:01I suspect the coating is more about resistance to pitting and low friction against the seals than it is about wear.Nessism wrote: The pistons were seized tight on my 750 calipers as well but eventually I managed to free them up. Unfortunately, two of the three caliper pistons were pitted and had to be replaced, at a fairly high price. Kawasaki isn't doing us any favors in that regard. I just checked the availability and it seems the pistons are no longer available from Kawasaki but there are a few kicking around on ebay. Fortunately, the piston seals and dust boots are still available. I strongly advise purchasing OEM parts, not aftermarket like K&L. I've had bad experiences with K&L brake system parts on three different occasions so use at your own risk. You can clean the calipers in solvent just as long as you keep any rubber parts you plan to reuse out of the sauce.
I wonder if there is a newer brake system that uses pistons of the same dimensions? The manufacturers often (always?) buy brake components from outside vendors. Sometimes competing models will use the same calipers with some irrelevant difference. For instance, the ZRX has a pair of six piston calipers up front. A full rebuild using Kawasaki parts is shockingly expensive. Suzuki used the exact same calipers on the Hyabusa, but with anodized aluminum pistons instead of Kawasaki's plated steel ones. The aluminum ones are a fraction of the weight and cost of the steel ones. Also, Suzuki sells the seals for a fraction of what Kawasaki charges. Exact same seals.
- Tvag06
10 Dec 2018 15:03
Thanks. I have it all ready to install but just too cold. I've got a heater but I only get any free time after 9pm. With work at 7am, my motivation is lacking.
'80 KZ440D - Stripped for rebuild -
kzrider.com/kunena/11-projects/611352-st...ng-a-rusty-80-kz440d
'04 Suzuki DL650 K4 V Strom
- Irish Yobbo
11 Dec 2018 13:42
Probably a little late, but partzilla do have OEM pistons - I bought two of them for my KZ750 a few weeks ago:
www.partzilla.com/product/kawasaki/43020-1096
They're not cheap though. It's strange that most caliper pistons are a 'cup' shape with the open end facing the pad, but the KZ pistons are solid chunks of steel. I guess that's for the softer compound on the surface to reduce brake squeal?
1981 KZ750 LTD
- Tvag06
12 Dec 2018 05:01
I've only had 2 bikes this kz750 and a cb550. The cb also had solid pistons. I've never seen a hollow one. lol
