1983 kz11oo fork seal questions...
  • tthunderdan
  • tthunderdan's Avatar Topic Author
20 Oct 2018 11:01
#792608
I am changing my fork seals. I go to slide the new fork seals down the inner tube and they are not the correct size, to big around.
I got the new seals with the bike from the previous owner, so I figured he maybe just ordered the wrong seals. So I look up on partzilla to figure it out and order some new seals. The new seals I have came sealed in kawasaki genuine parts baggie with part number 92049-1295, which is the same part number listed for the 83 kz1100 on partzilla.
Now I'm confused. Do parts ever get placed in incorrect labeled baggies? Twice? Or am I wrong about the seal part number I need? And do the barely readable numbers made into the seals mean anything in reference to part numbers?
As far as I know the forks are original equipment to the bike.
I do see a set of seals on ebay with the part number 92049-1102 that claims will fit the 83 kz1100, could that be what I need?
Any input to help me figure out what seals to get would be greatly appreciated.
Dan from Slippery Rock PA,
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
  • tthunderdan
Re: 1983 kz11oo fork seal questions...
20 Oct 2018 11:05
#792609
oooops somehow it got into the 'engine' category...
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
  • tthunderdan
20 Oct 2018 14:12
#792613
my fork tubes measure about 38mm and the new seals I have are about 42mm...
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
  • Nessism
  • Nessism's Avatar
20 Oct 2018 14:26
#792614
Not sure what to suggest. 38mm seals sounds right. All Ball's makes seals. Cheap too. You may have to go aftermarket.
The following user(s) said Thank You: tthunderdan
