Gear change lever
  • Ojisan rider
  • Ojisan rider's Avatar Topic Author
Gear change lever
13 Oct 2018 22:58
#792278
Aloha guys. Hopefully, I posted this in the right section.
Recently, I build up the motor to crankcase but I needed to take it apart again because I was stupid and forgot a small o-ring that goes on to one of the gear shaft. So started to take a part but you know, you already build-up a motor and have to take it apart again and my motivation was kinda low so called it for a day.
Long story short, I was playing with some of the parts I had and found that shift change lever I got off evilbay was wrong one. I'm pretty sure I bought one that said was for KZ, but it looks like it's for GPz. The lever bore that fit over the shaft is way bigger (more like 14mm instead of 12mm). So I went to evilbay again to get a correct one but unfortunately, the lever assembly was only used for three years (looks like started from 82' GPz, and was used for 83' KZ750 and 84' KZ700). Picture below.
Can I get this from any other year? Or if anybody have one laying around, PM me.
[img
I did look at something like EX500 and looks like it may fit, but not too sure about the thickness of the shifter.
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
  • Nessism
  • Nessism's Avatar
Re: Gear change lever
14 Oct 2018 04:50 - 14 Oct 2018 04:52
#792281
No eBay APP ID and/or Cert ID defined in Kunena configurationAvailable on ebay... Pretty sure you need the lever from a R1 or L model 750 so 3 years sounds about right.
Last edit: 14 Oct 2018 04:52 by Nessism.
  • martin_csr
  • martin_csr's Avatar
14 Oct 2018 07:07 - 14 Oct 2018 07:21
#792283
From the diagrams at Partzilla for the 82 KZ750-R1.
LEVER-ASSY-CHANGE,PD
13242-1049
Kawasaki Motorcycle 1983 KZ750-L3 GEAR CHANGE MECHANISM
Kawasaki Motorcycle 1982 KZ750-R1 GEAR CHANGE MECHANISM
Kawasaki Motorcycle 1982 KZ1100-B2 GEAR CHANGE MECHANISM
Kawasaki Motorcycle 1982 KZ1000-R1 GEAR CHANGE MECHANISM
Kawasaki Motorcycle 1983 KZ1000-R2 GEAR CHANGE MECHANISM
Kawasaki Motorcycle 1981 KZ1100-B1 GEAR CHANGE MECHANISM
Kawasaki Motorcycle 1984 KZ700-A1 GEAR CHANGE MECHANISM
note: some of the other components aren't the same on those models, so check the cross-reference. also, the ZX550 shares 1 or 2 parts.
Last edit: 14 Oct 2018 07:21 by martin_csr.
  • Ojisan rider
14 Oct 2018 13:48
#792300
Nessism wrote: Available on ebay... Pretty sure you need the lever from a R1 or L model 750 so 3 years sounds about right.
Yeah, I saw that one but the seller won't ship it to Hawaii or Alaska. I'll try message the seller though.
Yes. Price we pay to live in paradise, along with high cost of living.
But thanks for searching!
  • Ojisan rider
14 Oct 2018 13:50
#792301
martin_csr wrote: From the diagrams at Partzilla for the 82 KZ750-R1.
13242-1049
Yeah, I did tried in evilbay using KZ1100, KZ1000 and KZ750 but none had what I was looking for, so wanted to know if there's any other bike I could use it from.
But thanks for the info!
  • Nessism
  • Nessism's Avatar
14 Oct 2018 20:09
#792314
That lever will fit into a small flat rate box. I'll relay if the seller won't ship to you.
The following user(s) said Thank You: SWest, Ojisan rider
  • Ojisan rider
14 Oct 2018 20:54
#792316
Nessism wrote: That lever will fit into a small flat rate box. I'll relay if the seller won't ship to you.
Yeah, that's what I wrote to the seller. Hopefully, seller will reply to my message. Nothing as of now.
In any case, thanks!
  • Ojisan rider
15 Oct 2018 23:02
#792354
I got the reply back from the seller and just bought the item. Seller said will ship it to Hawaii using the flat rate box.
Thanks for all your help Nessism!
