83 KZ750N does the propeller shaft use metal gasket/space?
  • mmalone
  • mmalone's Avatar Topic Author
05 Oct 2018 15:09 - 05 Oct 2018 15:10
#791891
Hey guys,
I putting my project bike back together and noticed that I tore the metal gasket that's sandwiched between the transmission and propeller shaft.
Was thinking about replacing it but I cant seem to find any reference to it in the service manual. My question is:
1. Is this oem or did the previous owner just put it there?
2. If its oem, why is there 3 gaskets? I think and 2 thin.
3. Anybody got a part number?
Thanks.
Last edit: 05 Oct 2018 15:10 by mmalone.
  • martin_csr
  • martin_csr's Avatar
Re: 83 KZ750N does the propeller shaft use metal gasket/space?
05 Oct 2018 15:24 - 05 Oct 2018 15:50
#791892
There are quite a few places with parts diagrams. Kawasaki.com. CMSNL. etc. Partzilla is probably the easiest to use.
I'm not sure what part you need, but there are several different gasket-like shims in the front bevel gear assy & drive shaft final drive assy. I have no idea if they're supposed to be stacked, but each type comes in various thicknesses.
Partzilla > Kawasaki > motorcycle >1983 KZ750-N2 Spectre
For a manual. search eebbaayy for KZ750 Shaft manual. usually, several are available at reasonable cost.
Last edit: 05 Oct 2018 15:50 by martin_csr.
