Fork cover emblem
- 83550m
Fork cover emblem
14 Sep 2018 14:20
Just recently got a 1978 kz650 B2 and their is no front fork cover emblem on it .... went on Partzilla and for the life of me can't find a part #... any help would be appreciated.
1978 kz650 b2
1980 kz440 b1
1983 kz550m LTD
1980 kz440 b1
1983 kz550m LTD
Re: Fork cover emblem
14 Sep 2018 14:28
I don't think the 70s KZ650s had a fork cover emblem.
14 Sep 2018 14:43
The KZ650-B2, like all KZ650-B and C models (as well as some others) never came with a front fork cover emblem, so you will not find one for it. Ed
- 83550m
14 Sep 2018 14:50
Wow,.. OK thanks... just looks odd without one . .. i wonder if anyone has ever added something in that spot.
1978 kz650 b2
1980 kz440 b1
1983 kz550m LTD
1980 kz440 b1
1983 kz550m LTD
15 Sep 2018 04:32 - 15 Sep 2018 04:40
The lack of a fork emblem has come up from time to time, but I've never heard of anyone adding it. The emblem on my 81 650-CSR is mounted in conjunction with the brake pipe joint which is different than yours: the pipe joint & emblem bracket are mounted to the lower triple w 2 bolts, then the emblem is attached to the bracket. From eebbaayy pics the 650B steering stem has 2 bolt holes that appear to be similar in width to the 650-CSR. You could measure the width to see if making the improvement is within the realm of possibility.
Last edit: 15 Sep 2018 04:40 by martin_csr.
The following user(s) said Thank You: 83550m
15 Sep 2018 05:24
I added one to my Z1. Looked kinda naked without it.
kzrider.com/forum/24-wanted/601990-finned-engine-covers#720332
15 Sep 2018 05:45 - 15 Sep 2018 05:45
Well, that's a first. Were you able to add an emblem bracket & keep the stock brake pipe joint, and was the bolt hole spacing the same? Thanks.
Last edit: 15 Sep 2018 05:45 by martin_csr.
15 Sep 2018 06:00
I made my own bracket.
- 83550m
15 Sep 2018 09:32
This winter when i get it inside on my worktable I'll probably obsess about it and if i put one on I'll update this with some photos..
1978 kz650 b2
1980 kz440 b1
1983 kz550m LTD
1980 kz440 b1
1983 kz550m LTD
15 Sep 2018 10:33 - 15 Sep 2018 10:35
You could measure the center-to-center spacing between the brake joint mounting bolts, then go ahead & post the info here.
Adding the emblem might be pretty easy if the spacing is the same.
Last edit: 15 Sep 2018 10:35 by martin_csr.
- 83550m
15 Sep 2018 14:01martin_csr wrote: You could measure the center-to-center spacing between the brake joint mounting bolts, then go ahead & post the info here.
spacing looks to be 1 13/16" center of each bolt...
1978 kz650 b2
1980 kz440 b1
1983 kz550m LTD
1980 kz440 b1
1983 kz550m LTD
15 Sep 2018 18:01 - 16 Sep 2018 06:37
Thanks. Rough measurement on the 81 650-CSR is approx. 1-13/16.
I have a spare steering stem that I measured later >> it's about 45 or 46mm which is approximately the same as 1-13/16.
There are 2 or 3 different emblem brackets for the 650-CSR models & one type is kind of flat. The others have standoffs that kind of offset the bracket away from the steering stem. This type & the 650E/F bracket are used when there isn't a brake joint. Since the 650B should have a brake joint, you'll probably want to try the flat one.
Last edit: 16 Sep 2018 06:37 by martin_csr.
