Fuel Petcock Assembly R&R
  • ridedrms@pacbell.net
  • ridedrms@pacbell.net's Avatar Topic Author
30 Aug 2018 20:22 - 30 Aug 2018 20:24
#790025
Hey y'all
Bought a OK Hwy Patrol 82 KZ1000P1, which I'm in the process of resto-modding.
Here's my issue at the moment. The fuel petcock has been bypassed and I'd like to put it back to original spec. Problem is the assembly p/n has been superseded and the new p/n is for the '84 and on models and is not backwards compatible. The flange that mounts to the tank is smaller so the screws don't line up. Called the factory support hotline, no help from that quarter.
Does anyone know of a rebuild kit that fits the old assembly? Is there an adapter to fit the new assembly to the old fuel tank? Other suggestions? Thanks in advance.
Jon Neale
Last edit: 30 Aug 2018 20:24 by ridedrms@pacbell.net.
  • JMKZHI
  • JMKZHI's Avatar
Re: Fuel Petcock Assembly R&R
31 Aug 2018 05:39 - 31 Aug 2018 05:44
#790034
What's the bolt hole spacing? Is it a stock fuel tank?
51023-1039 (82-2001 models) & 51023-1375 (2002-05) are the only part numbers I've seen listed for the 1000P police motorcycles.
I have assumed both are 44mm as they have a large filter screen & use the same tank o-ring as other models with known 44mm bolt hole spacing.
Last edit: 31 Aug 2018 05:44 by JMKZHI.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
31 Aug 2018 07:25
#790047
What JMK ZHI said... The part number is the same from 1981 to 2001 and still available from Kawasaki.
tap assembly
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
