1992 KZ1000p Brake Lines
  • idmurp
  • idmurp's Avatar Topic Author
28 Aug 2018 06:49
#789903
So sent my brake lines off to a supplier to get new braided ones made up, and a couple of weeks later they have no record of receiving them....so anyone got a list of the lengths/fittings of the brake lines for a 1992 KZ1000p?
Ian
1992 KZ1000p in pieces
  • idmurp
Re: 1992 KZ1000p Brake Lines
31 Aug 2018 05:57
#790035
Gentle bump. If no ones got them Im a little bit stuck on how to do this!
  • M_a_t_t
  • M_a_t_t's Avatar
31 Aug 2018 06:21
#790039
Aren't they the same as a regular KZ1000 or KZ1100?
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
  • JMKZHI
  • JMKZHI's Avatar
31 Aug 2018 07:31 - 31 Aug 2018 10:02
#790049
If other models don't have the same part numbers, then you can't assume anything. Brake line lengths can vary depending upon things such as the forks, rake, handlebars & master cylinder, and possibly the front wheel size & frame.
If it's any help, the lower hoses for the 82 KZ1000P are listed as L = 550 mm. The 92 should have the same frame as the 82.
The upper hose may be different because the 92 has a more compact front brake master cylinder, so it could use a longer upper brake line.
Last edit: 31 Aug 2018 10:02 by JMKZHI.
  • TexasKZ
  • TexasKZ's Avatar
31 Aug 2018 07:54
#790050
According to Partzilla, the front upper hose (master to splitter) is the same part number as all the other KZ1000s 1982 forward. The other three hoses seem to be unique to the P10-P12. I don't know what is different,. Hopefully, somebody who has one can chime in with measurements.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
31 Aug 2018 08:26
#790054
Does the shipping company have a record of them being delivered? The reason I ask is I had the same situation with Galfer. They said they never got them but the tracking number shows them being delivered and they were eventually able to track them down.
Excellent service BTW...
Good luck,
Jim
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • z1kzonly
  • z1kzonly's Avatar
31 Aug 2018 11:14
#790059
Do you have a Harley/ Custom builder Bike Shop nearby?
All the new HD and Chopper stuff is 10mm.
Take some rope / cloths line etc. Mock up the size's you need. Like end to end . Banjo hole to banjo hole.
There are so many aftermarket items. They sell lines by 1 inch increments. All the fittings with different angles.
All these parts screw together.
If the shop is cool and respectful to all motorcycle riders? They should be able to help you!
Just don't go knocking on any Patch holder 1% er club house. They might beat you up for fun!Because you own a Rice burner :woohoo:
  • idmurp
31 Aug 2018 12:57
#790063
I'm in the UK so generally dont get the Harley VS Jap issues so much! ;)
The bikes in bits atm, Im waiting for the swingarm bearing to be removed by a local machine shop (they did not want to move) when its back if I have to Ill do the wire and guesstimate method.
The part numbers dont have the measurements and fittings they might be the same. I can get custom made up, that what I was doing when they went walkabout.
The tracking number says it was delivered, the company say they have no record and were not interested in talking to me when I phoned, and wont be getting any work from me again :(
  • gordone
  • gordone's Avatar
31 Aug 2018 18:22
#790078
I have good experice with Apex brakes, I only gave them model and year of my bikes and they made brake lines for me.
www.apexbrakes.com
Project:
  • idmurp
03 Sep 2018 05:07
#790192
They dont have any contact details on their website other than an email which always makes me nervous. Have you got a physical address/number for them?
Ian
  • gordone
  • gordone's Avatar
03 Sep 2018 05:45
#790196
I communicated with them back and forth on [email protected]
His name was Raymond
I’m happy with my parts I got from them. I got the company name from other members here.
Project:
The following user(s) said Thank You: idmurp
