master cylinder rebuild kit. 1978 Kawasaki 1000 ltd?
  • perrykz1000
  • perrykz1000's Avatar Topic Author
  • Have a safe day !!
27 Aug 2018 21:25 - 28 Aug 2018 05:49
#789892
Looking for a "REAR" rebuild kit. I saw a listing for a K&L 32-8052 is this the correct one? Anybody have part #s for the kit? Thanks.. Perry
Last edit: 28 Aug 2018 05:49 by perrykz1000. Reason: "SOMETIMERS" Meant to state "rear master cylinder repair kit"
  • z1kzonly
  • z1kzonly's Avatar
Re: master cylinder rebuild kit. 1978 Kawasaki 1000 ltd?
27 Aug 2018 22:09
#789893
I would be weary of the K&L items? Their pet cock O-rings shrink and distort.
Plus have you dis-assembled yours yet? Most cylinders are pitted with corrosion and not savable with honing. You need a 5/8 bore for dual.
I have made several 5/8 kits from the smaller single 14mm. I bore them to a fresh bore. But check into the re-pop round 5/8 that are on eBay for $89 last time I looked. I believe Rick the Britt sells them? Brakes are serious! Don’t barn job a bad core master cyl.
JMO
The following user(s) said Thank You: perrykz1000
  • z1kzonly
  • z1kzonly's Avatar
27 Aug 2018 22:15 - 27 Aug 2018 22:19
#789894
No eBay APP ID and/or Cert ID defined in Kunena configurationMan, they are down to $59!!!
There you go!
Unless you need original trapazoid style? Change to round!
Last edit: 27 Aug 2018 22:19 by z1kzonly.
  • perrykz1000
28 Aug 2018 05:46
#789901
Sorry, I thought I said rear master cylinder rebuild kit for my 1978 Kawasaki 1000 LTD. Meant to anyhoot.
  • z1kzonly
  • z1kzonly's Avatar
28 Aug 2018 07:21
#789904
Sorry. I missed that too. I must have went by the subject title.
  • hardrockminer
  • hardrockminer's Avatar
28 Aug 2018 07:31
#789905
Have you tried Z1 Enterprises? They sell a kit consisting of OEM parts. You can find it here. www.z1enterprises.com/rear-master-cylind...uild-kit-kz1000.html
Given that Z1E is selling OEM parts I imagine a local Kaw dealer could sell you the parts.
  • perrykz1000
29 Aug 2018 04:54
#789953
Hardrockminer , does look like Z1 Enterprises has the correct rebuild kit. I dont understand the $100.98 price not including the tax & shipping ?? Seems extremely high? May have to though. The rear master cylinder is working fine with no leaks. I just wanted to rebuild the unit because I dont know if it ever has been. I know the front cylinder and calipers have. Thanks for the link.. Perry
  • hardrockminer
29 Aug 2018 05:14
#789955
If the master cylinder is working fine then you may want to defer the expense and continue as is.
29 Aug 2018 05:41
#789956
I agree with hardrockminer. I've owned my 1977 K650-C1 since it was new and the rear master cylinder has never needed to be rebuilt; it works perfectly. I do recommend you flush the old brake fluid out using new brake fluid. I do that every 2 years or so to ensure no gunk builds up in the brake system. Ed
  • perrykz1000
29 Aug 2018 05:58 - 29 Aug 2018 05:59
#789958
I've done that. Put new tires on and noticed the rear brake hose the black rubber is cracked close to the fittings. Have new hose coming , planning on flushing system when I install the hose. Ive already replaced the front 3 hoses. Thanks , for the replies. Perry
Last edit: 29 Aug 2018 05:59 by perrykz1000. Reason: Added information
  • JMKZHI
  • JMKZHI's Avatar
29 Aug 2018 06:30 - 29 Aug 2018 06:30
#789960
Z1's pricing for the oem "kit" is about $10-15 less than what the dealer is going to charge. plus, Z1Ent lists the kit as in stock & has already rounded up the parts. If you try the dealer, they may or may not have all of the parts there in stock. :)
Last edit: 29 Aug 2018 06:30 by JMKZHI.
