How to take off rear brake lever
- Wilcocar
04 Aug 2018 11:39
My rear brake is sticking meaning the brake pedal won’t come back up unless I put my foot under it and pull it up. I know it’s not the caliper, completely detached from everything except the frame it’s still tough so I assumed it’s just gummed up in the lever itself I don’t know if it’s pressed on or seized up on there or what tried everything not coming off. Trying to take it off seamed self explanatory then this happened letting it sit for a bit with corrosion X on it to see if it loosens up. Maybe there’s something or a trick I don’t know!
1977 KZ1000 A1
Re: How to take off rear brake lever
04 Aug 2018 11:53
Have you disconnected the spring?
- slmjim+Z1BEBE
04 Aug 2018 12:29
They're notorious for developing rust on the pivot pin 'cause many owners seldom if ever lubed them. Keep it wet with penetrating oil, keep working it down & up while pulling on it. Patience. There's likely decades of rust & crud in the pivot. Assuming you removed the acorn nut & washer, it'll slide off eventually.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: Wilcocar
- Wilcocar
04 Aug 2018 15:29
Yes! I got it off! Works like a charm bought aftermarket speedo cable from Z1 enterprises was about 1 inch short damn!
1977 KZ1000 A1
