REAR WHEEL SLACK
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: REAR WHEEL SLACK
03 Aug 2018 10:53
#788132
All Balls has a set. There are three of them. Don't replace just one.
  • martin_csr
  • martin_csr's Avatar
03 Aug 2018 11:08 - 03 Aug 2018 11:09
#788134
The All-Balls-Racing kits from Z1Enterprises.com include the oil seals which is kind of handy. I probably wouldn't have serviced the speedo drive gearbox if not for that seal being in the kit. cleaning & lubing the speedo drive was easy.
Last edit: 03 Aug 2018 11:09 by martin_csr.
  • bluej58
  • bluej58's Avatar
04 Aug 2018 05:38 - 04 Aug 2018 06:30
#788166
I had some lateral movement in my back wheel and discovered that the swing arm pivot bolt was way too loose.
If you can spin the nut on your pivot bolt easily it is too loose, tighten it down to 22-28 foot pounds.
I tightened mine down to 25 ft lb's and have no more lateral movement ( do not over tighten)
78 KZ1000 A2A
Last edit: 04 Aug 2018 06:30 by bluej58.
