KZ1000 wheels on fitted to a GPZ900 unitrack?
  • rohalloran
  • rohalloran's Avatar Topic Author
18 Jul 2018 15:21
#787193
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationDoes anyone know if an 18" mag wheel off a KZ1000 (Cop Bike) will fit onto forks /swingarm of a GPZ900. I am building a cafe racer that is Half Honda, Half Kawasaki and would like to fit these wheels if possible. They have a Lester look about them.
Here is what I currently have:
[img
and the wheels in question are something similar to these:
Many thanks for any thoughts or feedback.
  • rohalloran
Re: KZ1000 wheels on fitted to a GPZ900 unitrack?
21 Jul 2018 13:09
#787343
Anyone have any insight at all?
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
21 Jul 2018 17:55 - 21 Jul 2018 17:56
#787361
The reason you don't have answer is probably because usually the refit is done the other way around i.e fitting a lighter wheel to the bike. I have a GPZ swingarm and GPZ900 wheel to my Z1R. It wasn't easy as the swingarm required a bit of sculpting to clear the brake setup.
The wheel was a different problem because I had to line up the sprocket with the wider wheel and keeping the wheel central, at the same time making sure the chain clears the frame.
I also found most of the time you can fit other wheels to different shafts by using different wheel bearings i.e if you have a smaller shaft try a bearing to match the wheel (outside diameter) and the inner diameter to match the shaft.
I assume you are using the GPZ900R motor.
If you don't get a clear answer and the wheel doesn't cost a fortune just give it a go.
I'll be interested in seeing the end result
Last edit: 21 Jul 2018 17:56 by Bozo.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
21 Jul 2018 19:08 - 21 Jul 2018 19:09
#787366
rohalloran wrote: Anyone have any insight at all?
I don't have an answer, but looking at the factory diagrams for an 84 GPz900 and a 1991 KZ1000P, they have a lot of parts in common.
  • The right hand axle spacer is the same
  • The speedo drive plate is the same
  • The speedo drive is not the same, but they share some internal parts
www.partzilla.com/catalog/kawasaki/motor...0-a1/front-wheel-hub
www.partzilla.com/catalog/kawasaki/motor...1000-p10/front-wheel
Also, All Balls Racing list the same front wheel bearing kit for the GPz900 and the 82-05 KZ1000P.  So you know your axle will fit.
www.allballsracing.com/25-1310.html
I think it's worth a try.  The two wheels were designed around the same time, so it's certainly possible that they maintained the same brake disk spacing.  That seems like the most likely issue.
Around 81/82 was the first major re-engineering of wheels, frames, engines, brakes and just about everything else since about 1973.  So it's likely that they didn't change that much in the next 2 years.
My dad's '74 Z1
'00 ZRX1100
Last edit: 21 Jul 2018 19:09 by DOHC.
  • rohalloran
23 Jul 2018 00:34
#787466
@bozo, @dohc Thank you both for your replies. I will look into tit a bit more but your replies have given me a bit more confidence to try it.
@bozo the frame is a Honda CB750K7 and will have a Honda CB750 engine fitted.
  • rohalloran
23 Jul 2018 08:35
#787485
I have found an eBay seller who will take the wheels back if it does not work so I will report what I find once I receive and have had time to fit.
