1984 KZ700 rear master cylinder rebuild
  • shockman54
  • shockman54's Avatar Topic Author
07 Jul 2018 17:22
#786591
Looking to source a rear master cylinder rebuild kit for my kz700, but no luck online. Does anyone know if other rebuild kits will work?
  • martin_csr
  • martin_csr's Avatar
Re: 1984 KZ700 rear master cylinder rebuild
08 Jul 2018 08:53 - 08 Jul 2018 09:44
#786619
The part is listed as NLA at Partzilla. ...PISTON-COMP-BRAKE Not Available 43020-1035
The cross-reference there indicates that a number of motorcycles use the same piston assy.
I did see a K&L 1000J Rr kit 32-8053 at Z1Enterprises.com.
Last edit: 08 Jul 2018 09:44 by martin_csr.
The following user(s) said Thank You: shockman54
  • Nessism
  • Nessism's Avatar
08 Jul 2018 09:50
#786620
Before popping the money for a kit be sure to peek inside the master for signs of corrosion pitting in the aluminum bore. You can't rebuild a deteriorated body.
