AIRBOX ??
  • GS963
  • GS963's Avatar Topic Author
AIRBOX ??
26 Jun 2018 05:33
#785910
Quick Question. WILL a 1978 KZ650 AIR BOX fit a 1977 KZ650?????
Re: AIRBOX ??
26 Jun 2018 05:48
#785911
Yes. Ed
The following user(s) said Thank You: GS963
  • martin_csr
  • martin_csr's Avatar
Re: AIRBOX ??
26 Jun 2018 06:26
#785912
Ed, are the 77-80 650 airboxes pretty much the same? I've assumed so since the airbox ducts are the same. Thanks.
Re: AIRBOX ??
26 Jun 2018 07:16
#785916
The parts manual I have shows the 1977 + 1978 KZ650 B & C models suing the same part number, but I'm not sure about the later airboxes. For example, I believe the 1979 KZ650 bikes had extra air valve stuff for emissions control, and I think those airboxes had an extra hole in them where tubing from the emission system attached. The box itself probably would fit, but there could be other differences. Ed
  • GS963
Re: AIRBOX ??
26 Jun 2018 09:27
#785919
Thanks!!!
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
Re: AIRBOX ??
27 Jun 2018 05:34
#785966
The 1979 kz650 airbox definitely has a hole for the air valve tube. It's maybe almost 1" diameter and in the center between the carb inlets. But otherwise I would guess they are the same or similar enough to use it you plugged the hole.
My dad's '74 Z1
'00 ZRX1100
