Shaft to chain conversions
- Retropower
13 Jun 2018 14:30
I'm in the process of fitting an engine with chain drive to a gt550 frame. I appreciate this is a kz website. I was just wondering if anyone knew the width of the kz pivot.
As I'm hoping to swap a kz swingarm in as I believe they are similar geometry.
Many thanks.
Rich.
Many thanks.
Rich.
Re: Shaft to chain conversions
13 Jun 2018 14:50
The width of the kz pivot is 235 mm, swing arm into frame.
- loudhvx
14 Jun 2018 06:25 - 14 Jun 2018 06:32
When I measure my spare Kz550D1 (dual-shock Gpz) swingarm, I get a width of about 225 mm (roughly +/- 1mm). The inner pivot tube might be about a mm longer as would the frame space between pivot mounts. I thought the standard Kz550 swingarms were basically the same width (maybe even the same length). They all use inner pivot tube 42036-1018.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 14 Jun 2018 06:32 by loudhvx.
