Magura Hymec System - The "liquid clutch cable"
  • Scirocco
  • Scirocco's Avatar Topic Author
  • Premium Member
  • Premium Member
04 Jun 2018 15:17
#784624
Does anyone have some experience with the Magura Hymec 167 System???
www.wieres.de/Modul/Online-Katalog/Kuppl...chnik/Magura%20Hymec
  • riturbo
  • riturbo's Avatar
Re: Magura Hymec System - The "liquid clutch cable"
04 Jun 2018 15:31
#784626
My friend has one on his 750 turbo. Works good .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • Scirocco
  • Premium Member
  • Premium Member
04 Jun 2018 16:00
#784627
Thanks for the info.
Has he any problems with the temperature and clutch leveler pressure point, (slipping clutch)?
  • loudhvx
  • loudhvx's Avatar
04 Jun 2018 16:28
#784629
That looks interesting.
  • Scirocco
  • Premium Member
  • Premium Member
04 Jun 2018 16:57 - 04 Jun 2018 17:05
#784630
I have a change to get a Magura Hymec System for testing on my project bike.
Does anybody know the exact clutch inner/outer, cable/cable bushing length under normal conditions and the clutch pulling travel for the actuator mechanism for a 900/1000?
Last edit: 04 Jun 2018 17:05 by Scirocco.
  • baldy110
  • baldy110's Avatar
04 Jun 2018 19:06
#784637
Yeah they work great but pricey.
  • Scirocco
  • Premium Member
  • Premium Member
04 Jun 2018 19:15
#784638
If the Magura Hymec System works great its worth the price!!!
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
29 Jun 2018 13:57
#786099
One of the fellas I raced with used one on his bike. I don't remember him bitching about it.
  • Move0ver
  • Move0ver's Avatar
29 Jun 2018 15:05
#786102
I heard the main benefit is that it avoids the issue where the regular clutch cable runs between the headers. Supposedly over time this line gets cooked and leads to clutch cable failure. Whether or not that's true, I don't know.
29 Jun 2018 15:33
#786103
Move0ver wrote: I heard the main benefit is that it avoids the issue where the regular clutch cable runs between the headers. Supposedly over time this line gets cooked and leads to clutch cable failure. Whether or not that's true, I don't know.
I can't imagine a clutch cable cooking on a KZ. I've owned my 1977 KZ650-C1 since April 1977 and never had any problem with the clutch cable getting too hot. Ed
  • Dr. Gamma
  • Dr. Gamma's Avatar
29 Jun 2018 17:21
#786108
I agree with 650ed, I never have cooked a clutch cable on any of my KZ's. If you route the cable correctly, and use the right length cable there should not be any problems. Its the people that use way too long of a clutch cable and jam it in there that have all the problems. I have the very same clutch cable on my KZ1000 Superbike since I built it back in 1979. I think I used a KZ400 clutch cable for just the right length I needed. I lube it once a year or so and never had a problem with it!!!
If you use the right length cable properly routed along with the late model clutch release (the one with all the little balls inside of it) you should not have any problems. Even with real heavy duty clutch springs, my clutch lever pull is not that bad!!!! I have to chuckle a bit when I see a hydraulic clutch set up on a KZ. I come from the KISS theory of modification, KEEP IT SIMPLE STUPID!!!! If the KZ's needed a hydraulic clutch set up, don't you think Mr. Muzzy would have had one!!!!!!
1986 RG500G 2 stroke terror.
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
29 Jun 2018 17:53
#786113
I like my rubber coated cable clip on the frame it doesn't mar the paint
