Brakes Dragging
  • Kevin STP
  • Kevin STP's Avatar Topic Author
Brakes Dragging
29 May 2018 05:51
#784290
Hey All, I have an 83 Spectre 750 and when it has been sitting, even overnight, the brakes drag . After riding for a few minutes they release. I have had to park it the past couple of yrs. due to health issues and am riding again. This has been something I can't figure out. I have changed Brake pads,cleaned caliper slideing parts and flushed the fluid. I need some help.
83 Spectre 750
  • TexasKZ
  • TexasKZ's Avatar
Re: Brakes Dragging
29 May 2018 06:29
#784295
How long has it been since the calipers have been disassembled, cleaned, and reassembled with new seals?
Crud can build up around the pistons, causing them to stick. Petrified seals can do the same.
  • Kevin STP
Re: Brakes Dragging
29 May 2018 06:41
#784297
It’s been a couple yrs. of no riding but back then I disassembled and cleaned all brake calipers and Master cyl. Seals seemed flexible and pistons were clean- not scored or pitted. I put in fresh fluid and bled the system. May be best to rebuild everything? Maybe upgrade to better brake system ?
83 Spectre 750
  • TexasKZ
  • TexasKZ's Avatar
Re: Brakes Dragging
29 May 2018 06:46
#784298
No need for extreme measures. It could also be that the tiny relief port in the master has gotten clogged.
Also, if the flexible lines are really old, one may have collapsed internally or may have serious barnacle build up,
The following user(s) said Thank You: Kevin STP
  • Kevin STP
Re: Brakes Dragging
29 May 2018 08:19
#784306
Thanks, I will check it out later today.
83 Spectre 750
  • Nessism
  • Nessism's Avatar
Re: Brakes Dragging
29 May 2018 11:37
#784312
The old rubber lines fill up with scale inside which is one reason they should be changed if still running the originals.
  • Kevin STP
Re: Brakes Dragging
29 May 2018 12:00
#784313
I will look for new lines and a Master Cyl. rebuild. Time to get back on the road !!!
83 Spectre 750
