Right side muffler stay p/n 35011A for '82 1100 ...brake lever way too stiff
  • RLBuddi
  • RLBuddi's Avatar Topic Author
25 May 2018 16:22
#784003
Right side muffler stay p/n 35011A for '82 1100 Spectre ...rear brake lever way too stiff. Any easy way to loosen that up? Please advise, thanks!!
  • martin_csr
  • martin_csr's Avatar
Re: Right side muffler stay p/n 35011A for '82 1100 ...brake lever way too stiff
25 May 2018 18:13 - 25 May 2018 18:19
#784021
Try putting some lubricant on the brake pedal shaft where it fits thru the muffler stay. If it's very bad, you might want to try a penetrating oil first, working it in by operating the brake pedal, then maybe spray some solvent to clean that out & let it dry, then apply some other lubricant after it's operating normally. You could disassemble & clean the parts, but that's a bit of work. not too bad, but harder than just applying the lube.
SHAFT-BRAKE,BLACK 43004-1037 .... Kawasaki Spectre KZ1100-D1 BRAKE PEDAL/TORQUE LINK diagram
STAY,MUFFLER,RH 35011-1110 .....note: 35011A is just the diagram reference number & not the part number.
Last edit: 25 May 2018 18:19 by martin_csr.
The following user(s) said Thank You: RLBuddi
  • RLBuddi
15 Jun 2018 07:16
#785198
That worked!!!! Thanks bro!!
