Tire Pressure
  • gordone
  • gordone's Avatar Topic Author
Tire Pressure
22 Apr 2018 23:03 - 22 Apr 2018 23:09
#782204
I have 1981 KZ650-D4, with 1981 z750L engine. with new tires. I have found a table in the service manual, please see attached table.
My weight is around 115 kg = 253.5 pounds.
What will the optimal pressure be then ?
Rear = 29 psi ?
Front = 26 psi ?
Project:
Last edit: 22 Apr 2018 23:09 by gordone.
  • TexasKZ
  • TexasKZ's Avatar
Re: Tire Pressure
23 Apr 2018 05:27
#782208
Oh nooooo! Tire pressure threads can get as controversial and angry as threads about the proper way to measure valve lash or which oil to use.
Most of the replies will fall into four categories----
1. Do what the factory service manual / frame info sticker says, no matter what. Always. No deviation at all.
2. Check with the tire manufacturer's website for recommendations. Tires have improved quite a lot since KZs were new. (This is my position.)
3. My great-uncle Bob knew a guy who said he once drove by a race track where somebody said that motorcycles one raced. He said that you should multiply the width of the handlebars by Pi, add your shoe size, then subtract the date, to find the proper pressure.
4. There is air in the tires? How did it get there and where can I buy more?
Good luck.
  • gordone
Re: Tire Pressure
23 Apr 2018 05:28
#782209
TexasKZ wrote: Oh nooooo! Tire pressure threads can get as controversial and angry as threads about the proper way to measure valve lash or which oil to use.
Good luck.
haha I take your point :)
Project:
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Tire Pressure
23 Apr 2018 07:02
#782215
I use what is suggested on the tire.
  • Nessism
  • Nessism's Avatar
Re: Tire Pressure
23 Apr 2018 07:24
#782220
SWest wrote: I use what is suggested on the tire.
Steve, what tires do you use and do they have the recommended pressure printed on them? I ask because I've never seen this before. I've seen tires with the MAX pressure shown, but never the standard recommended pressure.
And speaking of recommended pressure, I'm in the camp of following the recommendation of the tire manufacturer. Honestly though, I think the absolutely best method to set pressure involves measuring the tire pressure cold, riding the bike for a good number of miles in a manner befitting your personal style, and then stopping to measure for pressure rise. You should ideally see a pressure increase in the front tire of about 3 psi and the rear more like 5 psi. This is just a rule of thumb but the idea being there should be a noticeable increase. If the pressure isn't increasing, there is too much air.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Tire Pressure
23 Apr 2018 07:50
#782227
I generally run a few PSI lower than listed on the tires. Far cry from what was listed for the old Dunlops of the day in every way.
  • Nessism
  • Nessism's Avatar
Re: Tire Pressure
23 Apr 2018 07:59
#782228
SWest wrote: I generally run a few PSI lower than listed on the tires. Far cry from what was listed for the old Dunlops of the day in every way.
Steve,
Be careful you are not baselining off the MAX pressure. That's way too high, even if you are a few psi under.
  • TexasKZ
  • TexasKZ's Avatar
Re: Tire Pressure
23 Apr 2018 21:00
#782266
Steve,
+1
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Tire Pressure
23 Apr 2018 21:42
#782267
37-40 seems to be the popular pressures for the 230's.
  • gordone
Re: Tire Pressure
23 Apr 2018 23:44
#782268
Accordign to the tire pressure table I`m thinking:
Front: 28 PSI = 1.9 bar
Rear: 32 PSI = 2.2 bar
Can these be a good start point....
I have found on other forum for Pirelli MT66's the recommendation is:
front= 32-42
rear= 36-42
But these is higher than Kawa. recommend in the service manual?
Shall I start with front 32
and rear 36 then ?
I mean the pressure as physics force has been the same as long as we human has lived on the earth, and I assume the Kawa has sent up these numbers
based on weight + suspension + etc etc... ?
So why have higher pressure in 2018 then in 1981, is the reason because the old tire doesn't handled higher pressure?
Project:
  • gordone
Re: Tire Pressure
24 Apr 2018 01:36
#782270
I wiill start with:
front = 34 psi = 2.3 bar
rear = 38 psi = 2.6 bar
And see if I`m happy, I understand I can monitor the pressure and the wear and tear to see if its okay.
Stop me if I`m wrong :)
Project:
Re: Tire Pressure
24 Apr 2018 04:28 - 24 Apr 2018 04:28
#782273
gordone wrote: I wiill start with:
34 psi in the front tire sounds way too high to me as I suspect that will make the front tire hard as a rock. My front tire is a 100/90 V 19 Pirelli Sport Demon, and I run 26 - 28 psi in it. It works great. Ed
Last edit: 24 Apr 2018 04:28 by 650ed.
