Disc Brake Lock
- gordone
Disc Brake Lock
19 Apr 2018 10:17
I want to purchase a disc brake lock to my bike. I have measured the whole to be 7,5mm approx.
I found one called Oxford Screamer, but it has good lot of bad review.
Do you have some recommendation ?
Thank you all.
Thank you all.
Project:
Project:
Re: Disc Brake Lock
19 Apr 2018 11:44
If you can get a Sargent and Greenleaf or other quality padlock with a removable shackle you can attach it to the rear brake rotor as shown below. This would at least slow down a thief as he would need to carry the back of the bike and steer the front (at least it would take 2 guys). Ed
- DoctoRot
Re: Disc Brake Lock
19 Apr 2018 13:11 - 19 Apr 2018 13:11
this is what i use.
www.revzilla.com/motorcycle/kryptonite-keeper-disc-lock
A disk lock only needs to be good enough to deter casual theft. professional thieves typically aren't targeting KZs. What ever you get make sure it has a "reminder cable" I watched my buddy dump his bike because he forgot the disk lock was on. pretty sure it bent his rotor too.
Last edit: 19 Apr 2018 13:11 by DoctoRot.
The following user(s) said Thank You: Street Fighter LTD, gordone
- gordone
Re: Disc Brake Lock
21 Apr 2018 09:15
No eBay APP ID and/or Cert ID defined in Kunena configurationThank you,
I bought now ,
Xena XZZ6L Alarm Brake disc lock 6mm pin
I bought now ,
Project:
Project:
- KZB2 650
Re: Disc Brake Lock
21 Apr 2018 12:44
Looks like a pretty good solution but like the doctor says don't forget it as I could see where things could get bent....... a few months back when Steve wrote about his place getting cased out I had a dream someone rippped my bike and when I found it it was striped down.... when I seen the smooth bores were gone it upset me so I woke up shaking........ dreams can be pretty real sometimes.:silly:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- gordone
Re: Disc Brake Lock
21 Apr 2018 17:44
My plan is to use it all the time so I cannot forget it.
Project:
Project:
Re: Disc Brake Lock
21 Apr 2018 18:16
I have used one like this. Fits nicely on my passenger pegbracket when not in use.
www.walmart.com/ip/Kryptonite-EV-Red-Dis...=disc%20lock&veh=sem
- DoctoRot
Re: Disc Brake Lock
21 Apr 2018 18:37
I would still get the reminder cable. They are super cheap and work well
- JMKZHI
Re: Disc Brake Lock
22 Apr 2018 06:14Famous last words. :laugh:gordone wrote: My plan is to use it all the time so I cannot forget it.
Some locks come with a stretchy reminder cable that you connect to the handlebars.
I didn't use the reminder cable one time, then forgot about the lock and damaged the speedometer cable when rolling the bike off the center stand.
Re: Disc Brake Lock
22 Apr 2018 19:18DoctoRot wrote: I would still get the reminder cable. They are super cheap and work well
And get a REMOVE BEFORE FLIGHT red tag like aircraft have ( Looks Cool Too )
- gordone
Re: Disc Brake Lock
24 Apr 2018 23:40
I have purchase reminder cable today, typical me to forget the lock... heh
Thank you for your advise.
Project:
Project:
