'82 KZ1100 D1 Handlebar swap to 2" rise, ...need shorter length brake line.
  • RLBuddi
  • RLBuddi's Avatar Topic Author
18 Apr 2018 16:22
#782021
'82 KZ1100 Spectre ......I'd changed the handlebar to that of a 2" rise, however, the front brake line from master cylinder to is now too long and I was told I'd need that from a late 70's KZ900 ...from something that came stock with 2" rise bars. Not sure which bike it'd be though? Anyone off the top of their head know what length line I'm gonna need? If not, how does one determine length needed? Please and thank you!!
  • martin_csr
  • martin_csr's Avatar
Re: '82 KZ1100 D1 Handlebar swap to 2" rise, ...need shorter length brake line.
19 Apr 2018 07:13 - 19 Apr 2018 07:15
#782037
I disconnected the brake joint there at the forks, lowered it until the brake line looked right, then measured the overage.
Another way is to use a section of clear tubing as a measuring device.
If you get Goodridge lines or similar, be sure to include the fittings when calculating the length.
Goodridge straight banjos add a little less than 1" to the length.
Also, be sure to consider whether or not you need a different angle for the banjo at the Fr Br mc.
Last edit: 19 Apr 2018 07:15 by martin_csr.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
19 Apr 2018 09:17
#782039
Absolutely take advantage to change over to steel braided hoses. You can get custom made hoses from a hydraulic shop or online. Or Z1E has lengths with different banjo fittings available where you can assemble your own.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Nessism
  • Nessism's Avatar
19 Apr 2018 09:50 - 19 Apr 2018 09:50
#782041
You can make your own custom lines from Earl's parts quite easily and cheaply. I've got tutorial info if interested.
Last edit: 19 Apr 2018 09:50 by Nessism.
The following user(s) said Thank You: RLBuddi
  • RLBuddi
27 Apr 2018 20:53
#782515
Yes, very interested and thank you!!!
