crooked swing arm from factory?
  • DoctoRot
  • DoctoRot's Avatar
Re: crooked swing arm from factory?
10 Apr 2018 11:57
#781625
I found out the hard way when i made my custom swing-arm. I assumed the stock one was symmetrical, so i made my custom arm symmetrical. When i put the wheel in the new arm the sprockets didn't align. I measured the stock one and low and behold, slightly offset. It took a different set of spacers, and I had to cut out and refit one of the braces to work.
The following user(s) said Thank You: axel
  • axel
  • axel's Avatar Topic Author
10 Apr 2018 18:59
#781639
yes the swing arm in question is on a kz550A.
i’m not sure if i’ll attempt anything that precise. probably try to measure without removing the swing arm first.
but thank you for excellent illustrations and clarification!
1981 KZ550 (carburetor tuned for pod filters)
