Frame Tag Plate
  • gordone
  • gordone's Avatar Topic Author
Frame Tag Plate
27 Mar 2018 11:54 - 28 Mar 2018 03:34
#780900
Project:
Last edit: 28 Mar 2018 03:34 by gordone. Reason: Deleted
  • TexasKZ
  • TexasKZ's Avatar
Re: Frame Tag Plate
28 Mar 2018 05:26
#780924
Yes, but only in 1978.
  • gordone
Re: Frame Tag Plate
28 Mar 2018 08:04
#780929
TexasKZ wrote: Yes, but only in 1978.
I figure out wanted to search more in the forum and not spam...
Are you making for 1978?
Project:
  • TexasKZ
  • TexasKZ's Avatar
Re: Frame Tag Plate
28 Mar 2018 20:02
#780951
Yes, replacing the needle bearings with correctly sized bronze bushings should allow it to be installed, but won't it interfere with the rear brake?
  • gordone
Re: Frame Tag Plate
29 Mar 2018 01:03
#780957
My orginal question was id plate on the frame. Previus owner has temoved it when he painted the frame.
So I was looking into get one made for me.
Project:
  • TexasKZ
  • TexasKZ's Avatar
Re: Frame Tag Plate
29 Mar 2018 05:05
#780961
If there is enough clearance, it looks like it should work.
