`82 gpZ750 Front Brake Line Question
- Unicron0827
14 Feb 2018 05:20
Im new here, and new to this bike.
I picked up a really clean gpZ750 a couple months back to setup as a commuter bike to give my touring bagger a break.
My end goal for the build is something a bit street tracker inspired, while leaving most of the original bodywork intact, save swapping the front fender for a brace.
I started to tackle the handlebars last night, and there's just not enough play in the front brake line to fit the dime city tracker bars I planned on putting on here.
Which brings me to my question, does anyone know of a vendor that makes a 20" brace line from the double banjo to the front master cylinder, or the exact dimensions of the line i would need to have custom made?
I'm sure I'm not the first person to go down this road, so this has to have been done before, but as I'm new to this bike and its community, I'm at a loss for where to start.
Cron
Richmond, VA
"Watch out for the 5-0"
2013 H-D FLHR
1982 Kawasaki gpZ750 R1
1970 Volvo 164
1993 Volvo 945
Richmond, VA
2013 H-D FLHR
1970 Volvo 164
1993 Volvo 945
- Jack_Mills
Re: `82 gpZ750 Front Brake Line Question
14 Feb 2018 05:27
Check
www.z1enterprises.com/
74 kz400 D1
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
Thanks goes out to all folks who share their great knowledge teaching others about classic metric motorcycles.
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
The following user(s) said Thank You: Unicron0827
- ThatGPzGuy
14 Feb 2018 06:36
The '82 GPz750 is a great bike. Congratulations.
You can have brake lines made at hydraulic shops to your exact specs. Or, as Jack recommended, you can go to Z1E/MikesXS and get them in 2" increments with swivel banjos.
I have had a set made by these guys: EL Johnston They can make them while you wait in whatever color/material you want. The cost is similar.
One thing to keep in mind...note the banjo orientation and make sure they are the same as the ones you took off. Don't ask me how I know that...
Good luck,
Jim
Good luck,
Jim
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Unicron0827
14 Feb 2018 09:34
@ThatGPzGuy, Figured id check, since it seems you have one of these.
Im looking at Goodridge 10mm Brake Hose 833 series and fittings.
These should be a direct swap in to fit?
The PO put a lot of effort into keeping everything stock, and ideally any changes I make i plan to be in line with that and easily reversible.
so I'm assuming the line on here is stock as well.
Cron
Richmond, VA
2013 H-D FLHR
1970 Volvo 164
1993 Volvo 945
Richmond, VA
2013 H-D FLHR
1970 Volvo 164
1993 Volvo 945
14 Feb 2018 09:41
Making your own lines from Earl's parts affords you the latitude of getting the length perfect and the hose ends just right for your particular application. The parts are all made in USA and are easy to assemble by yourself.
- ThatGPzGuy
14 Feb 2018 09:48Glad to hear that. Mine is pretty stock with the exception of the paint and the exhaust. It is a joy to ride but down at the moment doing something similar to you. I opted for Galfer lines but as my projects tend to go, I am rebuilding the entire front brake system.Unicron0827 wrote: @The PO put a lot of effort into keeping everything stock, and ideally any changes I make i plan to be in line with that and easily reversible.
Jim
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Norton
15 Feb 2018 07:28
Yes, Be sure to visit Z1enterprises.com They have an entire selection of Goodrich custom brake lines in several lengths to fit your build.
- ajsfirehawk
15 Feb 2018 09:07
You MUST get new banjo bolts as well if you buy Goodridge lines. The fitting width is narrower than stock. I love the Goodridge product and have used them multiple times, but new banjo bolts and crush washers are a must.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
