Handle grips
  • gordone
  • gordone's Avatar Topic Author
Handle grips
10 Feb 2018 08:26
#778467
Hi,
I want to replace my handle grips, please see attached photo.
1. What is the best way remove it, use knife and cut it of?
2. Do you recommend some new handle grips webpages ?
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Handle grips
10 Feb 2018 09:10
#778473
If you want to reuse your grips try a head gun to soften the grips to remove.
If not use a knife.
  • gordone
Re: Handle grips
10 Feb 2018 09:12 - 10 Feb 2018 09:15
#778474
Thank you, is the size 7/8" ?
So I can use one of these:
www.z1enterprises.com/catalogsearch/result/?q=handle+grips
Must I use glue when install new one ?
Project:
Last edit: 10 Feb 2018 09:15 by gordone.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Handle grips
10 Feb 2018 09:25
#778477
SWest would say use hairspray.
  • gordone
Re: Handle grips
10 Feb 2018 09:27
#778478
hehe why hairspray ? it will make friction between the handlebar and the rubber ?
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Handle grips
10 Feb 2018 09:37 - 10 Feb 2018 09:38
#778480
It made it easy to push the grips on and when it drys it glued the grips on the handle bar.
Last edit: 10 Feb 2018 09:38 by Scirocco.
  • martin_csr
  • martin_csr's Avatar
Re: Handle grips
10 Feb 2018 12:15 - 10 Feb 2018 12:17
#778484
I used grip adhesive.
I prefer the stock grips, but they can be hard to find & expensive.
On my mountain bike (bicycle). I installed Oury grips similar to the ones at Z1Enterprises. the rubber is very soft & comfortable.
www.z1enterprises.com/handlebar-grips-7-...road-grip-black.html
Last edit: 10 Feb 2018 12:17 by martin_csr.
  • Nessism
  • Nessism's Avatar
Re: Handle grips
10 Feb 2018 19:33
#778502
I use the Oury grips on my 750 and love them. They have just the right amount of cushion and feel. My bike isn't trying to mimic stock though. I'd get stock or replica if that's your goal.
  • azman857
  • azman857's Avatar
Re: Handle grips
10 Feb 2018 20:20
#778505
I'm using a set of Biltwell's Recoils and I love em. Spray some WD-40 on the bars and in the grip. Don't get crazy with it. Slip them on and wipe off the excess WD-40. Your good to go!
  • gordone
Re: Handle grips
11 Feb 2018 01:58 - 11 Feb 2018 02:04
#778510
Nessism wrote: I use the Oury grips on my 750 and love them. They have just the right amount of cushion and feel. My bike isn't trying to mimic stock though. I'd get stock or replica if that's your goal.
www.ourygrips.com/road-street-grips/
So these pair will fit for my left and right side?
These is the same grip ? ON Z1Enterprice $9.95 and on ourygrips.com they cost $20.00 ?? strange ?
Thank you.
Project:
Last edit: 11 Feb 2018 02:04 by gordone.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Handle grips
11 Feb 2018 06:57
#778521
Scirocco wrote: SWest would say use hairspray.
:huh:
  • gordone
Re: Handle grips
11 Feb 2018 07:10
#778524
:huh:
hehe I will go for the hairspray and maybe use some lighter on it ? hehe
Project:
