Cap Fork Top
  • gordone
  • gordone's Avatar Topic Author
Cap Fork Top
05 Feb 2018 02:09 - 05 Feb 2018 02:10
#778239
I have rebuild my front forks with new good parts. I have a question for my new Cap Fork Top (Kawa 440291005), see attached picture.
I don`t have the air valve... what shall I do? what bolt can I use, is there special threads, I tried different sizes, but they are not fit 100%... ?
My plan is to install air valves later when I`m able to get 2, but for now is the plan jus to bolt of the wholes...
I can see that the end of the whole is graded in buttom?
Thank you all for helping me out.
Project:
Last edit: 05 Feb 2018 02:10 by gordone.
  • martin_csr
  • martin_csr's Avatar
Re: Cap Fork Top
05 Feb 2018 06:31 - 05 Feb 2018 09:48
#778247
I would take the air valve & fork cap to the hardware to see if you can figure out the size.
The 10mm headlight bolt of my 81 650-CSR seems to be a good fit into the air valve orifice. see pic.
I don't know what the thread pitch is. If you find something that fits, teflon tape could be used to seal the threads.
Last edit: 05 Feb 2018 09:48 by martin_csr.
  • gordone
Re: Cap Fork Top
05 Feb 2018 22:39
#778305
martin_csr wrote: I would take the air valve & fork cap to the hardware to see if you can figure out the size.
Hem I think I tested 10mm, I will do again... So I don`t need to be afraid to damage the seat in the buttom of the whole?
Project:
  • martin_csr
Re: Cap Fork Top
06 Feb 2018 06:45 - 06 Feb 2018 07:22
#778328
Maybe the bolt you checked had the wrong thread pitch?
I'm pretty sure the metric thread pitch on mine is 1.25 mm between threads.
standard pitch = 1.50 .... fine = 1.25 ... extra-fine = 1.00 ... JIS = 1.25 ... note: JIS = Japanese Industrial Standard
As for the bottom of the orifice, I don't think the air valve seats or seals there. The air valve has an o-ring.
Measure the depth of the orifice. also, look at how it's drilled at the bottom.
The 650-csr orifice is about 14mm deep. but the air valve threads are 10 mm in length.
I'm not sure how I'd do it, but you could try a socket screw or maybe a set screw. add washers &/or an o-ring as necessary.
Install the screw w teflon tape on the threads. with a set screw maybe put a small o-ring in the hole first.
The smallest available M10 socket screw is probably M10 x 16mm L.
M10*1.25 Pitch Fine Stainless 304 Allen Socket Cap Head Screws Bolt
Stainless Steel Button Head Screws A2 Hex Socket Bolts M3/M4/M5/M6/M8/M10 >>> Thread pitch not listed. ???
specialty set screw >>> ball point grub screw not recommending it. I just now stumbled across it on eb. the ball end is spring-loaded.
Last edit: 06 Feb 2018 07:22 by martin_csr.
  • gordone
Re: Cap Fork Top
10 Feb 2018 09:07
#778472
It was 10mm and normal threats as you said Martin, thank your for your inputs.
Today have I installed bolts with teflon, I think that is good enough?
See attached photo.
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Cap Fork Top
10 Feb 2018 09:21
#778475
No eBay APP ID and/or Cert ID defined in Kunena configurationI would use these kind of stainless M10 screws, looking a way better (invisible).
  • gordone
Re: Cap Fork Top
10 Feb 2018 09:24
#778476
Thank you, really good input !
He was not shipping to Norway, but has sent him a message.
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Cap Fork Top
10 Feb 2018 09:34
#778479
They should be available in a nuts and bolt shop in Norway.
I pay only 99 cent for 20 of them in my local shop, buy all my stainless screws their.
It is like a screw paradise.
  • gordone
Re: Cap Fork Top
11 Feb 2018 01:56
#778509
What do you call screws like these in English?
Project:
  • gordone
Re: Cap Fork Top
11 Feb 2018 02:08
#778511
I have found now :) thank you for these input, it will be nicer look on the bike now :)
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Cap Fork Top
11 Feb 2018 05:37
#778517
We here in Germany call them Madenschraube = maggot screw
  • TexasKZ
  • TexasKZ's Avatar
  • Busy
Re: Cap Fork Top
11 Feb 2018 06:01
#778518
gordone wrote: What do you call screws like these in English?
Usually, socket set screw, or just set screw.
The following user(s) said Thank You: gordone, Scirocco
