Anti-Theft Cable Lock
  • grumpy56
  • grumpy56's Avatar Topic Author
27 Jan 2018 15:12
#777886
A Sales brochure for my KZ1000J mentions an anti-theft cable lock and points to a small opening (hole) in the frame near the left shock. Anyone know what this is? I do not recall anything like that and always wondered what it is. Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
  • martin_csr
  • martin_csr's Avatar
Re: Anti-Theft Cable Lock
27 Jan 2018 16:13 - 27 Jan 2018 16:17
#777888
There was a cable lock that you could buy from Kawasaki. It slides into the frame & tucks away into the frame when not in use. Once installed, you can't remove it without cutting the frame. The thing is probably a bad idea as it lets water inside the frame. Typically, the frame would have a short tube projecting from the left side of the frame rearward of side cover or thereabouts & there should be a plug for the tube. NOS cable locks are listed on eebbaayy every now n then.
Last edit: 27 Jan 2018 16:17 by martin_csr.
  • grumpy56
27 Jan 2018 16:32
#777889
Thanks Martin!
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
  • martin_csr
28 Jan 2018 07:03
#777923
A few more photos. a couple from KZR.
  • grumpy56
28 Jan 2018 09:17
#777925
I don't notice the KZ1000s on the model listing. Was a different one used?
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
  • martin_csr
28 Jan 2018 11:07
#777926
Probably.
Here are the 2 pics that aren't showing. 1st one shows the barb that goes into the frame & the reason why you have to cut the thing out.
  • grumpy56
28 Jan 2018 15:32
#777933
Was wondering how it "connected". Here is my frame entry point, but I can't see the bottom where it would "hook".
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
  • grumpy56
28 Jan 2018 16:36
#777936
Here is pic.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
  • martin_csr
29 Jan 2018 05:17 - 29 Jan 2018 05:37
#777941
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationI don't know much about the thing, but I don't think there are any other frame modifications to accommodate it.
I think it's just designed to slide into the frame & the barb prevents it from being removed.
And like I said, the big problem with it is that it lets water inside the frame. There's usually a black plug fitted into the frame stub.
..... 82 KZ650-CSR plug
..... 1000J plug
Last edit: 29 Jan 2018 05:37 by martin_csr.
  • grumpy56
29 Jan 2018 06:06
#777946
Yes, what you show is the right plug. I had a plastic chrome plug laying around that fit, so I used that.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
