Flat o-ring
  • Ghostrider
  • Ghostrider's Avatar Topic Author
  • Florida KZRider & Z1RRider
Flat o-ring
24 Jan 2018 15:54 - 24 Jan 2018 16:16
#777718
While restoring my 78'KZ650-C2 I was bleeding my brakes with my fully re-built calipers and noticed it was leaking from the piston, all new pistons & o-rings were installed so how could this possibly leak? Bummer now I have to take them apart again, has anyone else had this problem and what did you do to fix it? I was just about to finally ride it too ... :(
The GhostRider ... :) Nick
59'CA102 Super-Cub / 05'VTX1300C5 / 05'C100ES BIZ / 07'XR650L / 78'KZ650-C2 / 78'Z1R D1 / 84'IT200L / 84'PE175E / 00'LT-A500F
80'GS1000G
www.facebook.com/groups/177698525750049/
www.facebook.com/groups/1993881067503984
Last edit: 24 Jan 2018 16:16 by Ghostrider.
  • Nessism
  • Nessism's Avatar
  • Ghostrider
Re: Flat o-ring
29 Jan 2018 06:26
#777949
OK so the verdict is that I now have front brakes! No more leaks! Turns out that I didn't pinch anything or twist the flat o-ring. I took it apart inspected it adjusted the positioning a little, put everything together and I found a clogged hose, so I unclogged it and did the bleeding and now my front brakes are done! Now I will order the rear rebuild kit and then the rear brake will be next.
No I use K&L rebuild kits and I sold and used many K&L products and never had any issues with them at all.
80'GS1000G
  • Ghostrider
Re: Flat o-ring
14 Feb 2018 20:32
#778784
Success! Finally after one year of restoration today was the first ride!!!
80'GS1000G
  • TexasKZ
  • TexasKZ's Avatar
Re: Flat o-ring
14 Feb 2018 20:37
#778785
Awesome! Where are the pics???
  • Ghostrider
Re: Flat o-ring
27 Feb 2018 19:25
#779520
I just uploaded a bunch in the KZ650 album
80'GS1000G
