KZ250 Wheels?
  • Average_250
  • Average_250's Avatar Topic Author
KZ250 Wheels?
24 Jan 2018 05:23
#777695
So as my first bike build draws to an end, a little 1980 cafe KZ250. I'm trying to find mag wheels that will fit the girl because the wires just don't fit the bill. I know that the belt 250's came with mags along with some of the 440's. I would like to know if either the belt wheels or 440 wheels will work on the bike with little modification as I seem to have gotten myself into a bit of a time crunch. Thank you in advance for any help.
  • martin_csr
  • martin_csr's Avatar
Re: KZ250 Wheels?
24 Jan 2018 07:42
#777699
Does your bike have a Fr disk brake or Fr drum brake?
  • Average_250
Re: KZ250 Wheels?
24 Jan 2018 09:20
#777704
Drums, nothing too fancy over here.
  • martin_csr
Re: KZ250 Wheels?
24 Jan 2018 10:18 - 24 Jan 2018 10:34
#777707
I don't think there was ever a KZ mag wheel w Fr drum brake. I could be wrong, though.
A disk brake is completely different, so the wheel is different.
Last edit: 24 Jan 2018 10:34 by martin_csr.
  • Average_250
Re: KZ250 Wheels?
24 Jan 2018 11:10
#777709
They did, at least the later ones did, there's a few on Ebay at the moment. The issue I'm finding is that they are off all belt driven bikes and I do not know if its as easy as swapping out the belt drive for the chain sprocket.
  • martin_csr
Re: KZ250 Wheels?
24 Jan 2018 14:05 - 25 Jan 2018 05:08
#777711
My comments were in regards to the Front wheel. I know there are mag wheels w Rr drum brake, but I didn't see the point in mentioning that if there isn't a front wheel you can use. I compared the Front brake & hub on a number of 250, 305, 400 & 440 models and didn't see any mag wheels w Fr drum. :)
Something you can do is poke around the diagrams at Partzilla. their site is the easiest & fastest to use, so you can zip around comparing one model to another. compare the hub components. the diagram drawings are usually fairly accurate, so in some cases you can see that a part is either similar or completely different without wasting time comparing part numbers or checking the x-ref.
Last edit: 25 Jan 2018 05:08 by martin_csr.
The following user(s) said Thank You: Average_250
  • 821000ltd
  • 821000ltd's Avatar
Re: KZ250 Wheels?
25 Jan 2018 13:11
#777759
I had a 1980 KZ 250 with mag wheels . Drum brakes front and back and chain drive. Gave it to my kid last year.
He's doing a cafe build on it.
82 KZ1000 LTD
Kerker 4 to 1
80 KZ 250
  • martin_csr
Re: KZ250 Wheels?
25 Jan 2018 13:23 - 25 Jan 2018 13:23
#777760
What's your location? Most diagrams are for the USA or North American models. I didn't see a Fr drum mag on anything.
Z250 (not a USA model)
Last edit: 25 Jan 2018 13:23 by martin_csr.
The following user(s) said Thank You: 821000ltd
  • 821000ltd
Re: KZ250 Wheels?
26 Jan 2018 04:16
#777792
I.m in Canada. My bike looks like that Z250 model. Dont know for sure where the bike came from originally.
82 KZ1000 LTD
Kerker 4 to 1
80 KZ 250
  • martin_csr
Re: KZ250 Wheels?
26 Jan 2018 05:07 - 26 Jan 2018 06:03
#777793
There are a couple of 250 Fr mag wheels w drum on eebbaayy, so maybe the type was sold in Canada.
I did not see a 250 Rr mag wheel on eb. The 440 Rr wheel hub components are different, probably bigger. I don't know if a 440 wheel can be used on a 250. the 440 is a bigger bike.
Brake shoe comparison. Using the Vesrah site, the 250 Rr brake shoes are 129mm diameter & 28mm width (VB-409 shoes). the 440s are 159.3 dia. x 30mm W (VB-413).
Last edit: 26 Jan 2018 06:03 by martin_csr.
  • oldblighty
  • oldblighty's Avatar
Re: KZ250 Wheels?
27 Jan 2018 14:20
#777875
We have a z250c single over here that comes with mag wheels , both front and rear with drum brakes , also the belt to chain conversion is an easy swap as far as I remember you just change over the belt wheels for the sprockets, back wheel has the same 4 bolt spacing.
