Brake Calipper Bleed Screw
  • gordone
  • gordone's Avatar Topic Author
05 Jan 2018 10:20
#776968
I have dual disc brake front, and on the right caliper has a earlier owner installed custom / bigger bleed screw, properly because he has damage the threats.... I want to install a new bleed screw with dust cover and be able to attach tube for taking out air etc...
So my questions is what to-do, is it possible to order larger bleed off screws for cars or something?
Can I install an helicoil and then be able to use original bleed of screw?
Please see attached picture for sizes and bolt etc...
Project:
  • martin_csr
  • martin_csr's Avatar
Re: Brake Calipper Bleed Screw
05 Jan 2018 10:59
#776972
I would try to figure out what size the threads are, then get a matching speed bleeder.
  • gordone
05 Jan 2018 12:53 - 05 Jan 2018 12:53
#776978
martin_csr wrote: I would try to figure out what size the threads are, then get a matching speed bleeder.
Thank you, will do.
Project:
Last edit: 05 Jan 2018 12:53 by gordone.
  • martin_csr
05 Jan 2018 15:39 - 05 Jan 2018 15:41
#776984
If the bleeder orifice has been retapped, I wonder if the bottom seat is a good fit for a different bleeder. I don't know if the taper on the end of different bleeder screws is the same or varies. I would want a perfect seal without leaks.
Last edit: 05 Jan 2018 15:41 by martin_csr.
  • gordone
07 Jan 2018 08:12
#777030
martin_csr wrote: If the bleeder orifice has been retapped, I wonder if the bottom seat is a good fit for a different bleeder. I don't know if the taper on the end of different bleeder screws is the same or varies. I would want a perfect seal without leaks.
I need to look into these, there are a seat now, but I need to see if the size is larger or not, thank you for your advise.
Project:
  • martin_csr
08 Jan 2018 07:46
#777052
If it wasn't leaking before, then I would guess you could get a replacement that is the same size as the old bleeder.
  • zed1015
  • zed1015's Avatar
  • Away
09 Jan 2018 10:13
#777106
Looks like an original bleed screw with a large nut welded on top because the original hex has been rounded off.
A new OEM bleed screw should be a straight fit.
  • gordone
09 Jan 2018 23:42
#777137
zed1015 wrote: Looks like an original bleed screw with a large nut welded on top because the original hex has been rounded off.
When I take bleed screw from another calliper it just drop in... so the whole is bigger...
So somebody have made it bigger... so the custom made bleed off screw is larger.
I will figure out what MM it has then order new bleed of screw in the same size.
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
10 Jan 2018 22:42
#777181
I think you need some of this bleeder screws (Metric 8 mm / 1 mm pitch)
Michael
  • gordone
10 Jan 2018 22:48
#777182
Thank you, I have written these down in my project notes :)
It need to come some later in my project, but good to have a plan :)
What I have not have decided is if I should make bigger thread on the brake caliper on the other site of the wheel...
so the bleed screw size is the same... for the look.... what do you think?
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
10 Jan 2018 23:04
#777183
I think you need some of this bleeder screws (Metric 8 mm / 1,00 or 1,25 mm pitch)
They are available in (M6x1, M7x1, M8x1.25, M8x1, M10x1, M12x1, ...) Europe and (3/8", 1/4", 5/16" NPT 1/4", ...) for GB and USA
cars and motorcycles like NORTON, Harley-Davidson and so on....
Check the threat pitch first with a gauge
Michael
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
10 Jan 2018 23:16
#777184
Sorry some double post, editing goes to an 404 side load error.
gordone, let the other side of the caliper as it is!!!
Don“t make you more trouble as you need only for the look, nobody will notice this tiny little bleeder screws are different!!!
Michael
