Tapered steering bearings
  • martin_csr
  • martin_csr's Avatar Topic Author
Re: Tapered steering bearings
04 Dec 2017 10:52
#775551
After installing the new, if you goof & have to drive them back out, do you have to buy a new set again?
  • ajsfirehawk
  • ajsfirehawk's Avatar
04 Dec 2017 13:41
#775558
That is what the manufacturer documents yes. I heated mine on a hot plate for the install, put the heat gun on it while I got my bearing puller and it slid off easily. I reused mine and haven't noticed any issues. Smooth steering operation on the lift and loaded up with me on it.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
04 Dec 2017 15:50
#775565
Some special steering neck bearing kits (outer races) have a less AD (- 0,05 mm) and can glued in with Loctite to
get a straight line and tension less seat, plus an easy out with a heat gun.
Patent-#.: 38 11 519 by Emil Schwarz
