Tapered steering bearings
  • martin_csr
  • martin_csr's Avatar Topic Author
04 Dec 2017 06:23 - 05 Dec 2017 05:19
#775522
When installing the tapered steering bearings, what will I get rid of? I know the races have to be removed & the cones aren't needed.
On the bottom of the steering stem there is a washer & o-ring. Do I keep the washer & o-ring, or does that stuff go? Thanks.
1981 KZ650-H1 CSR --- frame . >>> races, bearings, top cone, cap, locknut, waver washer, washer, steering head bolt.
1981 KZ650-H1 CSR --- front fork . >>> bottom >>> cone, washer & oil seal.
Last edit: 05 Dec 2017 05:19 by martin_csr.
  • Nessism
  • Nessism's Avatar
Re: Tapered steering bearings
04 Dec 2017 06:47
#775523
You get rid of pretty much everything. The new kit should have everything you need, assuming it's complete. That said, when installing new tapered rollers into my 750 I had to add one extra seal on the top because the All Balls kit I bought didn't have provisions. It took a bit of jury rigging but figured it out. The stock bearing was shielded on top but not sealed with a rubber lip, but I fixed that.
  • martin_csr
04 Dec 2017 06:54 - 04 Dec 2017 06:55
#775524
Thanks. Does the bottom tapered bearing have a seal or o-ring of some sort?
Last edit: 04 Dec 2017 06:55 by martin_csr.
  • Nessism
  • Nessism's Avatar
04 Dec 2017 07:02 - 04 Dec 2017 07:09
#775525
The seal is located just below the bearing on the triple clamp.
Last edit: 04 Dec 2017 07:09 by Nessism.
  • martin_csr
04 Dec 2017 07:05 - 04 Dec 2017 07:06
#775527
The stock oil seal fits on a washer, so you keep those two, then?
Or are you saying the bearing kit has a seal.
In the photo at Z1Enterprises I'm not sure what all I'm looking at. doh.
Last edit: 04 Dec 2017 07:06 by martin_csr.
  • Nessism
  • Nessism's Avatar
04 Dec 2017 07:14
#775528
Looking at the Z1 Kz650 bearing page, one of those washer w/seals goes under the bearing on the steering stem and the other sits on top of the top bearing.
  • martin_csr
04 Dec 2017 07:19 - 05 Dec 2017 05:28
#775529
Thanks. I couldn't tell for sure what those were. looks so obvious now. :blush:
Z1Ent --- Steering bearing kit w oil seals --- AB22-1014 . >>> 30 x 52 x 17 (lower) & 30 x 48 x 14 (upper) >>> KZ650 et al
Last edit: 05 Dec 2017 05:28 by martin_csr.
  • Nessism
  • Nessism's Avatar
04 Dec 2017 07:25
#775530
On my bike the rubber lip of the top washer/seal contacted the top edge of the frame steering neck, it didn't fit inside the frame like it does on the bottom.
  • martin_csr
04 Dec 2017 07:44 - 05 Dec 2017 06:22
#775532
So did you have to trim the seal to make it fit?
Is the top seal really needed? I would prefer to have a seal there, but just wondering since Kawasaki didn't have one at the top.
Last edit: 05 Dec 2017 06:22 by martin_csr.
  • Nessism
  • Nessism's Avatar
04 Dec 2017 08:51 - 04 Dec 2017 09:34
#775535
Martin, I debacled my way through the bearing install for my 750. I wound up with two different All Ball's kits, as well as the Kawasaki top bearing and shield part, neither of which I used.
First off I installed the top bearing on the lower steering stem. Oops. That's why I ordered the second All Ball's kit.
So I fixed that and proceed to install the upper bearing only there was no seal. I wasn't happy about that so I started ordering the OEM Kawasaki parts figuring they would be better only I couldn't figure them out either (still no seal).
A bit of fussing stumbled on the fact that the lower seal, when installed over the top bearing, resulted in the rubber lip contacting the top of the frame. Call it dumb luck. At any rate, after figuring this out I installed everything and called it done.
The photo of the kit from Z1 shows that they seem to have a seal now. I don't remember that when I did my bike a few years back. Hopefully everything you need will be in that kit. If not, you may have to find a second lower seal for the top. I think the frame dimensions are such that the lower seal fits inside on the bottom but just contacts the frame on top.
Good luck
Last edit: 04 Dec 2017 09:34 by Nessism.
  • martin_csr
04 Dec 2017 09:06 - 05 Dec 2017 05:39
#775538
Okay, thanks. Something that confused me was that the first couple of steering bearing kits I saw didn't show the seals. Then I didn't really look at the other kits very carefully. just a quick glance.
without the oil seals.
Z1Ent --- Steering bearing kit --- KL31-5834. . Mfg part # SSK400
Last edit: 05 Dec 2017 05:39 by martin_csr.
  • ajsfirehawk
  • ajsfirehawk's Avatar
04 Dec 2017 10:23
#775546
I replaced the ball bearings with an All Balls kit about 6 months ago. I gave myself the opportunity to do it twice since I installed the kit and left the top seal sitting on the workbench. Gaaaaa!
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
