custom cables?
- lgyee4
custom cables?
29 Nov 2017 18:24 - 29 Nov 2017 20:46
I need both throttle cables for my shafty, but can't find the push cable. And I put on some Superbike bars and the stock lengths are too long for the stock routing. What do you guys do for this? Is there a vendor that has both throttle cables? Custom maker? Clutch cable to too long too..
TIA
TIA
2 stroke rider
TZ 250, TZR 250, RD 400, RZ 350, RZ 500, WR 200, KDX 200, Vespa ET2
And one 4 stroke: 1979 KZ1000ST
Last edit: 29 Nov 2017 20:46 by lgyee4.
- loudhvx
Re: custom cables?
29 Nov 2017 18:30 - 29 Nov 2017 18:33
The easy, and not-too-expensive answer is Motion Pro. They will make it any length you want, but you'll have to wait till they make more if they don't already have that length made.
You can also just shorten them yourself if you are really good at soldering. (It's not really a beginner's project.)
You might be able to find some from other bikes.
If it's for the Kz1000 ST, you might want to add that to your signature so we know what bike you are asking about. Maybe someone knows what else works on the ST.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 29 Nov 2017 18:33 by loudhvx.
The following user(s) said Thank You: lgyee4
- lgyee4
Re: custom cables?
29 Nov 2017 20:49 - 29 Nov 2017 20:50
Thanks loud!
I've found some that will work but the curve in the tubes at the throttle tube housing are problematic. The push has a different radius so it clears the pull tube housing.
2 stroke rider
Last edit: 29 Nov 2017 20:50 by lgyee4.
