Footrests
  • gordone
  • gordone's Avatar Topic Author
Footrests
16 Nov 2017 03:11 - 16 Nov 2017 03:11
#774671
Hi,
Please see attached diagram for footrests.
www.partzilla.com/catalog/kawasaki/motor...ootrests-81-82-h1-h2
34003 and 34003B has the same Kawa part number (34028-1018) ???
Is these correct is it the same part physical?
When I check ebay etc. the part number 34028-1018 is for Right side... ?
Project:
Last edit: 16 Nov 2017 03:11 by gordone.
  • TexasKZ
  • TexasKZ's Avatar
Re: Footrests
16 Nov 2017 04:33
#774675
What I see there is
34003 = 34003-1063. Bracket left footrest
34003A = 34003-1064 bracket Right footrest
34028 is the actual footrest itself, the front ones are the same, the rear are different right and left.
  • gordone
Re: Footrests
16 Nov 2017 04:42 - 16 Nov 2017 04:51
#774676
I`m sorry I typed in wrong number is was talking about 34028 and 34028A (left and right) and both have the same Kawa number 34028-1018...
So what I was wondering if left and right was identical for the footrest it self... and you gave me the answer in last replay :)
Thank you :)
Then I will purchase two of them.
Plan will be to purchase these:
www.cmsnl.com/products/step-assy_340275062/
Project:
Last edit: 16 Nov 2017 04:51 by gordone.
  • martin_csr
  • martin_csr's Avatar
Re: Footrests
16 Nov 2017 05:43 - 16 Nov 2017 05:49
#774683
So what I was wondering if left and right was identical for the footrest it self... and you gave me the answer in last replay.
Yes, the Fr LH & Fr RH footrests (step assy) are identical as TexasKZ noted.
Fr LH = 34028-1018
Fr RH = 34028-1018
The rear are different from each other, so the Rr LH footrest has a different part number than the Rr RH.
Rr LH = 34028-1024
Rr RH = 34028-1025
Last edit: 16 Nov 2017 05:49 by martin_csr.
