Something is awry with the steering.
- gordone
15 Nov 2017 01:32
When I drive my bike I must turn the steering some to the left, not munch but some...
The wheel are not "pulling" to the side, it`s feel like the steering wheel itself not bended and not stright, but as fair as can see that is not the problem.
Summary:
Bike is running fine and I have driven for long trips these summer without any problem, but I must turn the steering som degree to the left for compensating...
I have problem to see where the problem it... so I wanted to ask what experience you have with ti, and what it`s common to be the problem?
If you need more information or more clear information, maybe my English is not clear enough ?
hehe
Just give me a replay and I will try to explain more or check up things...
Summary:
Project:
Project:
Re: Something is awry with the steering.
15 Nov 2017 04:38 - 15 Nov 2017 04:41
Last edit: 15 Nov 2017 04:41 by martin_csr.
- Kidkawie
- I bleed premix
15 Nov 2017 06:06 - 15 Nov 2017 06:06
Try disassembling the whole front end and re-assemble.
Check rear wheel alignment.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 15 Nov 2017 06:06 by Kidkawie.
15 Nov 2017 06:15 - 15 Nov 2017 06:18
Also, the fork assembly can be twisted without anything being bent. If so, it is easy to fix.
Raise the front wheel off the ground. Insure that the top fork clamp (triple clamp) nuts are properly tightened around the fork tubes. Loosen, but DO NOT REMOVE the following--
lower fork clamp nuts
fender mounting bolts
axle clamps
axle nut
Shake the handlebars from side to side, or take hold of the front wheel and shake it from side to side. Do not be violent, shake just enough to loosen everything up.
Now re tighten to factory specification----
Axle nut
Axle clamps
fender bolts
Assuming that nothing is bent, this should get everything back in alignment.
Of course, it could just be bent handlebars.
axle clamps
axle nut
Axle nut
Axle clamps
fender bolts
Last edit: 15 Nov 2017 06:18 by TexasKZ.
15 Nov 2017 06:33 - 16 Nov 2017 05:12
Other checks. block the engine, then loosen all of the clamp bolts, then see if you can straighten the front end. You may need to loosen the big steering stem bolt & also the axle nut.
Block the engine & loosen the triple tree clamp bolts, then spin the fork tubes to see if they have a sticking point. this may indicate a bent fork tube. you might be able to do this one fork at a time. loosen one side, spin the tube. retighten. then do the other fork.
Lay a piece of glass on the fork tubes. It should lay flat. I've never done this.
A method from an old reply by steell that might realign the front end. Tighten/torque the top triple tree clamp bolts. Loosen the bottom triple tree clamp bolts, then do a shake down my vigorously compressing the forks by pushing down on the handlebars several times. you may need a helper to steady the motorcycle. a couple of big guys would probably have better luck doing this. I don't recall exactly what else he may have done. you may also need to loosen the big steering stem bolt & axle nut.
Last edit: 16 Nov 2017 05:12 by martin_csr.
- gordone
15 Nov 2017 09:38
Thank you all for feedback
I will disable the fork anyway, so I will look for bend parts then. Cross my fingers that the problem is only a small twist
I will update you with the results. It can take some months try rebuild most of the bike in the winter, but I wanted to get some more acknowledge about these problem, and now I know much more, thanks to you !
Thank you again.
Thank you again.
Project:
Project:
