Arebthe kz650 and kz750 steering head the same len
- iaturtleboy
06 Nov 2017 21:34
Im trying to see what the length on the front end of the frame(steer tube?) on my 1980 kz750e .It is for a front end swap. Is it the same length as a kz650
1980 kz750 E 4cyl
- les holt
Re: Arebthe kz650 and kz750 steering head the same len
07 Nov 2017 04:09
Same length.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
07 Nov 2017 04:36 - 07 Nov 2017 05:03
What 650 is it? guessing a 70s model, but if it's a csr, the triple tree will bang against the 750E tank. pretty sure.
Last edit: 07 Nov 2017 05:03 by martin_csr.
- iaturtleboy
07 Nov 2017 09:57
Im using a gsxr front end im looking at cognito for the stem just was wondering if the 1980 kz750 and a kz650 share th 're same neck size as hes asking fir the measurement. My bike is 16 hours away:(
1980 kz750 E 4cyl
07 Nov 2017 10:02 - 07 Nov 2017 10:08
From various frame diagrams at Partzilla the KZ650 & 750E use the same bearing races, so the measurements should be the same. The 92048-006 & 92048-008 races are used in a bunch of models. Additionally, All-Balls-Racing has a fork conversion lookup. enter a model, then see what other forks can be mated using the available tapered bearing sets.
Last edit: 07 Nov 2017 10:08 by martin_csr.
The following user(s) said Thank You: iaturtleboy
