Speedo Re-cal ?
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
Speedo Re-cal ?
28 Oct 2017 22:57 - 28 Oct 2017 23:01
#773927
Collecting all the parts ( rim, tire and spare hub so far ) to covert my 77' KZ1000A's front 19" tire to an 18", What are you guys using for the speedometer recalibration ? I'm assuming that the speedo will read even more faster now than the actual speed.
Can the speedo gear be changed out or are you using a different speedometer drive gear from a different motorcycle that will fit the KZ axle ? I think that the KZ400's axle is smaller than the KZ1000 ?
77' KZ1000A
Last edit: 28 Oct 2017 23:01 by kzdcw.
  • TexasKZ
  • TexasKZ's Avatar
Re: Speedo Re-cal ?
29 Oct 2017 06:29 - 29 Oct 2017 06:30
#773931
The gears in the speedometer drive are replaceable. After a quick perusal of the parts diagrams at Partzilla, it looks like Kawasaki used the same 9 tooth pinion gear on virtually all of its street models in the KZ era. However, there seems to be both a 25 tooth and 26 tooth ring gear. Both gears fit a wide variety of models, so you may want to copy the figment list from Partzilla before you go shopping.
Last edit: 29 Oct 2017 06:30 by TexasKZ.
  • martin_csr
  • martin_csr's Avatar
Re: Speedo Re-cal ?
29 Oct 2017 06:33 - 29 Oct 2017 07:17
#773932
Speedometers are usually re-calibrated by changing the magnets.
Within the realm of possibility. Assuming it will fit, install a 24T speedo drive gear. 41060-1025. This will lower the speedometer rpms to about 2070 which is approximately 8% less than the typical 2240. Doing this might get your speedo closer to the actual speed. I've never heard of anyone doing this.
Last edit: 29 Oct 2017 07:17 by martin_csr.
  • kzdcw
  • 77' KZ1000A
Re: Speedo Re-cal ?
29 Oct 2017 17:12
#773965
Martin, it seems like the 25-T Speedo gear is for the KZ400 with the 18" Front Wheel and the 26-T Speedo gear is for the KZ1000 19" front tire like mine ?
I always thought going to a "Higher" teeth count speedo gear, since the front wheel is turning faster, would help correct the speedometer reading which I "think" would be registering higher in indicated speed with the 18" front tire installed ?
Am I looking at this wrong ?
Also, I'll order that speedo drive gear ( 24-T ) if you think it will fit and match up to speedometer "pinion" gear ?
77' KZ1000A
  • TexasKZ
  • TexasKZ's Avatar
Re: Speedo Re-cal ?
29 Oct 2017 21:39
#773985
Here is the list of bikes using the 24 T. It is a long one.
www.partzilla.com/product/kawasaki/41060...c3318993ddbf8d652953
  • kzdcw
  • 77' KZ1000A
Re: Speedo Re-cal ?
30 Oct 2017 03:56
#773989
Well I ordered it. Hopefully it will fit and work?
77' KZ1000A
  • TexasKZ
  • TexasKZ's Avatar
Re: Speedo Re-cal ?
30 Oct 2017 04:31
#773990
Fingers crossed.
  • martin_csr
Re: Speedo Re-cal ?
30 Oct 2017 06:34 - 30 Oct 2017 13:01
#773995
I could ask myself the same question. hee. A 24T lowers the number of cable revs per mile, so this should fool the speedometer into a lower mph output. If the cable spins fewer times per mile, this has the same effect as spinning it fewer times per minute, which lowers the speedometer reading. At 60 mph w a 26T, the speedo cable spins 2240 times per mile and per minute. If you're going 60 mph w a 24T, the cable is only spinning 2070 revs per mile per minute and the speedometer will sense a lower speed & give a lower output than the actual speed. A defective speedometer that was showing an incorrect 65 mph, will now show a speed closer to the actual 60 mph with a 24T.
My numbers were for a 19" wheel. You may need to go with a 23T. ZX600 et al. again, assuming it fits.
The KZ1000-P police has an 18" front wheel w 26T speedo gear & 9T pinion.
Last edit: 30 Oct 2017 13:01 by martin_csr.
