Front Master Cylinder
  • grumpy56
  • grumpy56's Avatar Topic Author
24 Sep 2017 11:15
#771579
Have a front master cylinder that leaks and need to find a replacement. Anyone know of where a new one can be found or a replacement that will work on my KZ1000J? Thank you.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
  • grumpy56
Re: Front Master Cylinder
24 Sep 2017 16:08
#771588
Also, any tips for keeping it from leaking?
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
  • ajsfirehawk
  • ajsfirehawk's Avatar
24 Sep 2017 18:38
#771605
Forgive me for being Captain Obvious, but from where is it leaking? If it is around the plunger a simple rebuild kit from K&L should clean it up.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • grumpy56
25 Sep 2017 04:44
#771626
Good question, you would have thought I would have mentioned it!!!!! It is leaking around the top cover. This is the second time in about 2 years. Cleaned it off real good yesterday, lots of white residue on the sealing surface. Don't know if that will help though.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
