Question on Wheel Bearing replacment
  • KZ1000LTDPENNSYLVANIA
  • KZ1000LTDPENNSYLVANIA's Avatar Topic Author
16 Sep 2017 07:45
#771001
Hello KZ Riders,
I want to replace my front and rear wheel bearings because they are 38 years old and sometimes on the road I think I hear that sound a bearing makes when they are starting to go plus I would feel safer knowing I am riding on new bearings.... so I received my new ones from Z1 Enterprises and looking at the shop manuals here.
Wondering if the '76-'79 A4-D3 Z1R would be the same for my 1979 KZ1000 LTD?
1979 KZ1000 LTD
Re: Question on Wheel Bearing replacment
16 Sep 2017 08:08 - 16 Sep 2017 08:11
#771004
To see if the bearing part numbers are the same -
For the 1979 KZ1000-B3 (LTD) take a look at:
For the 1980 KZ1000-D3 (Z1R) take a look at:
www.powersportswarehouse.com/p/Kawasaki#...00-D3-1980/070081L-4
To compare parts for other models click on "New Model" at either of those links and plug in the bike's model number you wish to search. Ed
Last edit: 16 Sep 2017 08:11 by 650ed.
The following user(s) said Thank You: KZ1000LTDPENNSYLVANIA
16 Sep 2017 08:38
#771010
Yup both 601B6206 BALL BEARING,#6206 so....
Procedure to remove old/install new bearings would be the same if I am using the shop manual for the D3 - wouldn't it?
(I can't find a shop manual for my bike)
1979 KZ1000 LTD
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
16 Sep 2017 09:48
#771014
Should be the same just mind the axle spacer and be patient.
To ease the reinstall put the old bearing in the freezer over night first. Oh, if it has the rubber seals carefully pry them off and check to see if the grease is adequate. If not, pack some more in there.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
16 Sep 2017 12:43
#771025
I would say put the new bearings into a freezer.B)
