Fork oil replacement 83 Spectre 750
  • jenningsjesse
  • jenningsjesse's Avatar Topic Author
31 Aug 2017 15:13
#770099
This isn't like the 81 ltd I changed fork oil in. The manual only states to remove top caps to replace oil in my 83 Spectre 750. Well I removed rubber caps, and there is metal plugs with possible snap ring. Anyone know how to remove these metal plugs so I can get oil back in forks? Attached is a picture.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Fork oil replacement 83 Spectre 750
31 Aug 2017 15:36 - 31 Aug 2017 15:36
#770100
Push the plugs down to lower the fork spring pressure on the circlips and remove the circlips with a screw driver
Last edit: 31 Aug 2017 15:36 by Scirocco.
The following user(s) said Thank You: jenningsjesse
  • martin_csr
  • martin_csr's Avatar
31 Aug 2017 15:39
#770101
If the forks are on the bike, block the engine. the plugs are under spring pressure & can go flying.
  • jenningsjesse
31 Aug 2017 16:17
#770105
Got it. I figured it out.
