Replacement belt for kz440
  • TexasKZ
  • TexasKZ's Avatar
Re: Replacement belt for kz440
02 Sep 2017 07:14
#770189
02 Sep 2017 08:37
#770193
One of the things you probably should measure on the old belt is the "pitch length." The video below explains an easy way to accurately measure it. Ed
The following user(s) said Thank You: TexasKZ
  • marypsi
  • marypsi's Avatar Topic Author
11 Sep 2017 12:47
#770738
Do you happen to know how many teeth the back sprocket has when paired with the 125T belt versus the 129T belt? Thank you!
1982 kz440 ltd, belt drive, named "Isabella"
11 Sep 2017 13:54 - 11 Sep 2017 13:55
#770741
Take a look at the link below (you may need to cut & paste it into Google for it to work). It looks like the back sprocket (part number 42041-5002) has 60 teeth, and the belt in the diagram (part number 59011-1001) has 125 teeth. Ed
Last edit: 11 Sep 2017 13:55 by 650ed.
  • vwrabbit
  • vwrabbit's Avatar
01 Oct 2017 10:35
#772100
From what I've found, Harley Sportster belts should work. Same pitch, 14mm. Just need to verify length/tooth count.
1982 KZ440 former LTD
1975 CB125S
2006 VT600 VLX
