KZ75o Speedocable
  • JWKZ750
  • JWKZ750's Avatar Topic Author
KZ75o Speedocable
27 Aug 2017 07:36
#769863
No eBay APP ID and/or Cert ID defined in Kunena configurationI bought this motion pro cable for my 77 Kawa KZ750 and its too short by about 2 inches. The manufacturer (Motion Pro) assures me its a stock cable. Where can I get the proper length cable? Seems my front brake caliper is a bit in the way, but the cable would still be too short.
Here is the one I bought:
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ75o Speedocable
27 Aug 2017 08:03
#769865
I had to buy one for a KZ 900 LTD. The calipers being behind the forks made the stock one too short.
  • davido
  • davido's Avatar
27 Aug 2017 10:51 - 27 Aug 2017 10:52
#769876
2 inches isnt so much (as the actress said to the bishop!). You might be able to lose most of that by rerouting it.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 27 Aug 2017 10:52 by davido.
  • davido
  • davido's Avatar
27 Aug 2017 10:54
#769878
Then again,maybe not. You could try
www.z-power.co.uk/
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • JWKZ750
27 Aug 2017 12:16
#769879
davido wrote: Then again,maybe not. You could try
www.z-power.co.uk/
thanks for this. and yeah it seems the brake caliper is in the way
  • martin_csr
  • martin_csr's Avatar
27 Aug 2017 12:56 - 27 Aug 2017 16:06
#769881
How long is the old cable? what's the length & part number of the new cable?
Last edit: 27 Aug 2017 16:06 by martin_csr.
  • JWKZ750
27 Aug 2017 21:11
#769906
martin_csr wrote: How long is the old cable? what's the length & part number of the new cable?
Unfortunately I threw the old cable out when it snapped when I was riding. I'll measure the new cable tomorrow but the part number is in the ebay listing i posted above
  • martin_csr
28 Aug 2017 05:44 - 28 Aug 2017 06:18
#769909
Search Z1Enterprises.com for KZ650 speedometer cable.
Check the Motion Pro catalog -->> Kawasaki applications pdf -->> KZ650B & KZ750B.
Then compare those numbers to the cable you received.
From the diagrams for the 750B, there are two part numbers for the B1-B2 & B3-B4. The 650B has the same speedo cable.
Last edit: 28 Aug 2017 06:18 by martin_csr.
  • JWKZ750
28 Aug 2017 13:38
#769923
martin_csr wrote: Search Z1Enterprises.com for KZ650 speedometer cable.
Dumb question: how do i know if I have the b1-b2 or b3-b4?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
  • JWKZ750
28 Aug 2017 14:34
#769925
Thanks so much. I will check the engine number but without having looked, looks like I have a B1:
