KZ550 Throttle Cable
- Tanker2017
14 Aug 2017 15:20
Hello, I am new to the forum. I have an '81 KZ550. The previous owner put shorter (drag) bars on the bike that cause the throttle cable elbows to hit the tank if turned full to the right. Is there a common solution/product for this problem? I like the bars, but the tank has already been scratched due to this issue. Thanks for any help!!
- JR
Re: KZ550 Throttle Cable
14 Aug 2017 15:56
Have you tried loosening the 2 screws underneath the RH switch block and throttle housing and rotating the switch block/housing counter clockwise. A small adjustment here might move the metal elbow just far enough forward and upward to avoid dinging the tank.
Of course depending on how tight the cable is that might cause another problem.
The following user(s) said Thank You: Tanker2017
- M_a_t_t
14 Aug 2017 19:02 - 14 Aug 2017 19:09
(After posting I think I said the same thing as JR)
You might try loosening and rotating the whole throttle assembly part. It would swing the elbows up, depending on how close it is it might get you in the clear.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
Last edit: 14 Aug 2017 19:09 by M_a_t_t.
