I have a question - but not sure which section
  • aprintbuyer
  • aprintbuyer's Avatar Topic Author
  • Owner - restorer - 1980 KZ750-H1 Ltd
31 Jul 2017 00:24
#768014
Hi - didn't want to post in wrong area - but I have a question regarding a fuel filer cap not closing and fuel evaporating -
Couldn't find a section on where to get advise on an overhaul / replace spring etc
  • martin_csr
  • martin_csr's Avatar
Re: I have a question - but not sure which section
31 Jul 2017 05:54
#768019
What motorcycle is it and does it have the stock fuel tank & fuel cap? I would investigate the latching mechanism and If possible take it apart & clean it to see what's what. maybe it's full of crud or the problem is the spring? just guessing at this point.
Related. If it still has the original gasket, then you'll probably want to replace that as old rubber becomes hard. Z1Enterprises.com.
The following user(s) said Thank You: aprintbuyer
31 Jul 2017 06:33
#768021
Please add your bike's exact year and model to your signature line. Kawasaki made 3 different 1980 KZ750 models (KZ750-E1, KZ750-G1, and KZ750-H1) and they do not all use the same fuel tank cap or other parts. Ed
  • aprintbuyer
31 Jul 2017 06:37
#768022
Thanks - its a 750 Ltd 1980 - I managed to find an image on the net of what the inside gasket looks like on a new replacement - and on checking mine - there is no gasket at all ! - so i have just ordered a couple of rubber sheets I can use to a make new one -
I will also take apart and clean anyway -as will do no harm -
thanks for posting
  • martin_csr
31 Jul 2017 10:28
#768041
It's been a while since I've had mine apart, but I seem to recall that there are some tiny parts that could get lost.
