Belt drive 750E?
  • Mickey1031
  • Mickey1031's Avatar Topic Author
Belt drive 750E?
23 Jul 2017 23:48
#767577
Have any of yall converted a chain final drive to a belt drive?
Can it be done?
What dose it take to do this?
The difference between a "biker" and a real Biker, saying you own a bike, and actually owning a bike, Not a "T" shirt
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Belt drive 750E?
24 Jul 2017 19:23
#767644
SWest wrote: Why?
Double that.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jul 2017 19:33
#767646
Can you even get belts and pulleys anymore?
24 Jul 2017 20:25
#767652
SWest wrote: Can you even get belts and pulleys anymore?
He may be able find used pulleys, but buying a used belt would be a mistake. However, I have seen a NOS belt for sale for a mere $350! Ouch! I love my chain drive bike! Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jul 2017 20:39
#767654
I wouldn't trust NOS rubber.
  • GPz550D1
  • GPz550D1's Avatar
24 Jul 2017 22:21
#767664
Mickey1031 wrote: Have any of yall converted a chain final drive to a belt drive?
Can it be done?
Have had chain drive Kawasaki bikes for forty years and dislike chain drives. The noise, mess, maintenance, etc. of them. Would convert my bike to belt or shaft drive, but it is not practical, for me at least. Won't ask you "Why" do you want to do this.
1981 KZ550-D1
  • martin_csr
  • martin_csr's Avatar
25 Jul 2017 05:07 - 25 Jul 2017 07:38
#767673
I wouldn't even consider converting to a belt. But as a can it be done exercise.
Belt. From checking the diagrams at partzilla the KZ750-K Belt uses the same belt as the 90-96 Vulcan 500, so it's possible a good new part might be available. probably expensive. A used belt could be 20+ yrs old. not sure how durable they are or the service life.
Output shaft. this is probably the hardest part. the ZX750-A has the same output shaft as the 750K. So the output shaft might could be swapped or possibly the transmission. or complete engine unit. also, a guy would need to check the clearance for the front pulley.
Rear wheel. the 750-Belt has the same rear hub shock damper as the 750E & the hub coupling is similar with some of the same parts, so adding the 750K pulley might be the easy part. if not, he might be able to install a 750K rear wheel & swing arm and convert the Rr disk brake to drum brake. for a drum brake, either the 750K stuff or 650-csr. probably the latter.
Last edit: 25 Jul 2017 07:38 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
25 Jul 2017 06:36
#767678
Having owned bikes with all three drive systems, I can attest to how fabulous a good belt drive is. It is very quiet, clean and maintenance free. Since it is so much lighter than chain or shaft, more power gets to the wheel. The only down side is the cost, which over the life of a bike might not be so different from chain and sprocket cost given the long life of the belt.
That being said, finding a good belt is going to be a challenge these days. In addition to what Martin_CSR wrote, you will need to replace the chain guard with a wider belt guard. I wonder if a belt from a Sportster or a Buell might be close enough?
  • martin_csr
25 Jul 2017 07:49 - 25 Jul 2017 08:03
#767681
Belt. JC Whitney lists a couple of universal fit aftermarket belts for the Vulcan 500. 126T & 132T.
I also checked the PartsUnlimited catalog but didn't see anything for the EN500.
Related. beware scoot works. they list stuff for the vulcans but there are some reviews from dissatisfied customers. esp. at kawasakimotorcycle.org. in case they have anything that will work on a KZ.
Last edit: 25 Jul 2017 08:03 by martin_csr.
  • Nerdy
  • Nerdy's Avatar
  • Away
25 Jul 2017 09:07
#767691
Nebr_Rex wrote:
SWest wrote: Why?
Double that.
Why do people do half the things they do with their vehicles? To see if they can. :)
I just picked up a KZ440 LTD as a project bike and I'm considering leaving the belt drive in place, just for grins. The belt (according to the PO) has only about 500 miles on it, so what the heck.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • AtLarge
  • AtLarge's Avatar
26 Jul 2017 04:29
#767724
34 years and 21000+ miles on my OE belt. Have had a back up hanging in the garage for years just in case. Still haven't needed it. No complaints here. IF it can be done and IF you have the time and money to throw at it I'd say worth it.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
